05-09-2009, 09:10 PM | #1 |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
| Integy's adapters Quick question, does it have spines inside the adapters or do i have to drill the stubs for the cross pins to use it in a clod axles? |
05-10-2009, 02:24 AM | #2 |
Neither... They slide over the Stock 12mm Brass hex.
05-10-2009, 09:16 AM | #3 |
Really? huh... what's the cross pins and o-rings for? I assumes it to drill the hole in the stubs and o-ring to hold the pin in. Also from the picture I don't see where you can slide the 12 mm hex in... Perhaps someone could show a picture with that adapter with 12mm hex in?
05-11-2009, 08:07 PM | #4 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
What adapter are you asking about? Do you have the part number? I have Integy 12 to 14mm adapters and they just slide over the original hex... |
05-13-2009, 10:37 PM | #5 | |
Newbie Join Date: Dec 2006 Location: Lacey
05-14-2009, 05:40 PM | #6 |
I can see where you slide the 12 mm hex in... Thanks for claification... The pic that I posted dosn't show well where the 12 mm hex goes in, plus there were cross pins and o-rings which made me confused, perhaps it is for another style than clod.
05-14-2009, 05:48 PM | #7 |
Those are probably for a Savage. They use cross pins.
05-14-2009, 05:51 PM | #8 |
Rock Crawler Join Date: Jul 2007 Location: clearfield
I think the ones you are looking at, are made for CVD's and straight axle's... The end of the axle is 8mm( i think), and has a hole through it.. The adapter goes on, put the crosspin in, the O ring holds the pin from sliding out...
05-14-2009, 06:13 PM | #9 |
Now that really does make sense to me... Thanks |
05-14-2009, 09:19 PM | #10 |
Rock Crawler Join Date: May 2009 Location: Welderville just south of benchviseland
RC4wd makes a wicked-simple set for around 20 dollars. They make a bunch of different sizes from what I've seen?
05-14-2009, 09:31 PM | #11 | |
05-15-2009, 01:46 PM | #12 |
Yep, that's what I saw. Would something like that work?
05-15-2009, 04:51 PM | #13 |
Those are cool.... I'm using the JP pack knucles.. So, going with integy adapater/wideners as shown above pic. When going lipo, I will go that way, it's a good deal 20 bucks for 4. Many thanks to everyone for their info. I'm learning a lot everyday from this site... It becoming my all time fave... |
