09-15-2004, 08:48 PM | #21 | |
| Re: UTRCRC or Gecko 2 Chassis? Quote:
Try http://www.utrcrc.com Guys... don't forget the Comp testd Mach I chassis from MTPA/Centipede Engineering!! Or the Rockraider chassis! I have this one ready to go... Mach I w/ Beefcake High Clearance links. | |
09-15-2004, 09:19 PM | #22 |
Rock Stacker Join Date: May 2004
How much? also do you have a chassis like that for TXT running gear? Send me a email so we can talk. lee@rockage.com |
09-15-2004, 09:48 PM | #23 | |
How much? I'll have to tally it up and get back to you. :? I have heard that it is possible to fit the TXT tranny into the Mach I chassis. After looking closer it would seem that some hole drilling might be needed to mount tranny, upper and lower mounts. | |
09-15-2004, 10:31 PM | #24 |
Pebble Pounder Join Date: Sep 2004
I thought the Clod was 4 wheel independent steering???? I'm going to have to buy a kit to make it that way? Why is the Clod stock steering bad?
09-16-2004, 02:17 AM | #25 |
Quarry Creeper Join Date: Aug 2004 Location: salt lake city
I have a gecko 2 and for comps the utrcrc V2 beats it out hands down Kaetwo and pinchflat did their homework well this chassis is a great comp chassis Go for he V2 man its awsome. Or the mach 1 chassis looks great to and is a proven comp chassis I don't know much about it I have not seen one in our comps yet. I know I said what all of you did but I have to give my two cents two RockSurfer |
09-16-2004, 06:46 AM | #26 |
Quarry Creeper Join Date: Aug 2004 Location: Grand Forks, ND
TJEEPERMAN / The stock Clodbuster is not INDEPENDANT 4 wheel steering. Both front and rear axles turn at the same time. What they are talking about is being able to turn the front and rear wheels different from one another. like this /---/ \---\ or just the front or rear tires without | | /---/ \---\ moving the other ones. The stock Clod setup can only turn them like this /---/ \---\ | | \---\ /---/ Hope this helps you understand. I don't have any actual pics on my computer to show this. I hope you can understand the diagrams. Hey, how are you guy's able to get the pics posted? I am fairly new here. Thanks. |
09-16-2004, 06:47 AM | #27 |
Sorry, It messed up my diagrams. I'll try to get some pics up if I can figure out how to post them here.
09-16-2004, 07:12 AM | #28 |
Quarry Creeper Join Date: Sep 2004 Location: Michigan
Wow those high clearance links are saweet! 8O
09-16-2004, 07:48 AM | #29 | |
Rock Stacker Join Date: Jun 2004 Location: Central, Ok
09-16-2004, 01:59 PM | #30 |
I did a little bit more research after I read the last few posts and correct me if I'm wrong but it looks like in order to have independent front and rear steer I will have to get another Servo and steering setup for the rear. I'm guessing in order to get them to steer independent of eachother I will have to wire them a certain way? Will any controller work or will I have to have one that can handle that. I ordered a Clod over ebay with controller but all I know about the controller is its a futaba trigger style radio.
09-16-2004, 07:20 PM | #31 |
Pebble Pounder Join Date: Aug 2004 Location: Moab
you'll need a third channel for the rear steer, and not the 'on-off' third channel on most surface radios. There's info on this site about how to add a toggle to get rear steer w/ three channels.
11-02-2004, 02:14 PM | #32 |
TTT Since there has been some discussion going on about chassis lately. |
11-02-2004, 06:59 PM | #33 |
The Wheels Keep Turning Join Date: Jan 2004 Location: Phoenix, Arizona
Hands down the Mach1 is the best choice. The Mach1 chassis only is a great price, $85! The Mach1 chassis is an awesome competition chassis and the designers have been crawling longer than anyone else around here. The gecko's are not good comp trucks, but they are very nice CNC machined chassis. The Mach1 is also a machine made chassis, so it's high quality. I think the Mach1 plates are cut with high pressure water jets on a computer controlled machine, really nice quality. and remember, there are allot of other things you have to get for your crawler: Motors $40 High torque servos $80 for 2 super rooster $85 used servo mounts $30 top link mount $30 etc............... the Mach1 is available here: http://www.rcrockgear.com/ here's my Mach1: more pics of it here: http://rccrawler.com/postt3369.html and here's another Mach1: http://rccrawler.com/postt3405.html http://www.monstertruckparts.com.au/...I%20trucks.htm .. |
11-02-2004, 07:12 PM | #34 |
Rock Stacker Join Date: Oct 2004
the gecko extended version of the chassis is the best that is wut i got and it is monstress 17 inch wheelbase it is a real nice and clean chassis Nate |
