11-16-2005, 01:00 PM | #1 |
Pebble Pounder Join Date: Aug 2005 Location: Vallejo
| parallel wiring Question
Running SooperRooster,intogy 55T motors. I ran parallel,But when I turn the rear axle(by hand) the front turns backward's,Do I have to reverse the wiring going from rear to front motor? |
11-16-2005, 01:24 PM | #2 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
I don't really understand what you are talking about with turning the axle by hand (they are completely separate from each other mechanically). But to answer your question, you must have one motor wired reverse from the other. |
11-16-2005, 02:56 PM | #3 |
If you rotate the rear tires, the front turn too, or vice versa. Motors are little generators. And they should turn the same direction.
11-16-2005, 03:04 PM | #4 | |
