01-26-2010, 01:31 PM | #1 |
Newbie Join Date: Jan 2010 Location: central
| anyone try INTEGY chassis??
Has anyone tried this INTEGY evo chassis for the clod & if so any repots & pics would be appreciated.. Thanks http://www.integy.com/st_prod.html?p...37&p_catid=107 |
01-26-2010, 04:14 PM | #2 |
Quarry Creeper Join Date: Mar 2006 Location: Lutz
Thats way too expensive for a chassis and plus...your talking about Integy here.....not the best quality. You can get a REALLY nice setup for 200 bucks. I say make your own chassis or get a used one...and big bore traxxas shocks and your choice of axles (since you posted in the Clod forum...i think you got the axles figured out)
01-27-2010, 05:05 AM | #3 |
found the same setup as the website for $100 so just curious if it was worth it..
01-27-2010, 08:52 AM | #4 |
Newbie Join Date: May 2006 Location: WOODBRIDGE
NO NO NO NO dont do it.....i got one of the integy chassis(not the same one you are looking at) it was horrible....do some shopping around and buy something good....i ended up using a stock ax10 chassis for my clodbuster axles and it works good |
01-27-2010, 09:22 AM | #5 |
Rock Crawler Join Date: Jul 2008 Location: Port Angeles
NOOOOOOOOOOOOOOOOOOOOOOOOOOO! That chassis is a total and complete waste of perfectly good aluminum and graphite. I had one of the previous versions of it that I got too cheap not to buy - ended up cutting it up to make brazing jigs out of |
01-27-2010, 09:32 AM | #6 |
on the rocks got any pics of the ax10 chassis & clod axles???
01-29-2010, 04:52 AM | #7 |
Newbie Join Date: May 2009 Location: San Francisco
I don't have this exact chassis but I can tell you this, there are a lot of integy haters around. Think of it like Walmart & Microsoft there are just too many little guys and consumers going after the bigger companies, ppl can come up with a thousand reason why you should not buy from Walmart. Another ten people here probably want to jump me and say they used integy stuff and suck for a fact blah blah. I only speak from my own experience they make pretty decent stuffs for the price but just like anything else, you look hard enough and you'll find something better. By the way, I'm a patriot and let's make sure everyone buy a Ford, no Toyota j/k I drive an 09 Tundra.
02-01-2010, 12:39 PM | #8 |
i do have some pics of the ax10 with the clod axles.....let me find them and i will post them up
02-01-2010, 12:42 PM | #9 |
thanks would be appreciated
02-01-2010, 12:49 PM | #10 |
here is one pic of it wit the body on.. I have more at home and will post them when i get home clod axles ax10 chassis wheely kig shocks imex rubicon soft tires integy 65 turn motors |
03-04-2010, 08:04 AM | #11 |
Quarry Creeper Join Date: Jun 2008 Location: Lapeer
| ___ I'd like to see some pic's of how ya' did that using an AX-10 chassis,...please.
03-04-2010, 03:34 PM | #12 |
Newbie Join Date: Feb 2010 Location: New York
I spotted the Integy EVO kit as you mentioned on ebay for $99. Since my main truck will be the TXT-1 that I am currently building, I couldn't see a reason not to buy the EVO kit to use with my clod axles. I plan to use this as a beater truck, no crawler. The carbon fiber chassis plates are actually a clone of my tamiya lightweight TXT-1 chassis, only slightly shorter in length. In fact, I was surprized to see that the TXT-1 tranny would fit the mounting holes on the carbon fiber chassis. The kit also came with link bars, steering links and rod ends. They look to be useable and well made for what I need. I will not be using the two nylon upper center link mounts as I have the aluminum Integy version. The shocks are decent, wish they had aluminum cap ends instead of plastic. I like the complete set of shock mounts (4 that attach to the link bars and 4 that attach to the chassis). What I hate about the kit: The chassis support bars are plain weird! Instead of a straight piece of aluminum, they sculpted them. I will be machining them on the lathe or make new ones like the TXT-1 uses. Also, I do not like the anodized blue, clashes with my color scheme. There is a battery tray or whatever it is? I will not be using that either! No instructions telling you how everything goes together. Some of the items were confusing as to how to mount them and I am usually real good with building with no instructions. I wasn't sure where to put the body posts or what the four 1" aluminum spacers were used for? I will post pictures as I get close to finishing the axles. Last edited by mavrim; 03-04-2010 at 03:37 PM. |
