View Poll Results: Do you run bearings on you Clod crawler axlea | |||
YES.....but its not important! | 6 | 21.43% | |
YES | 10 | 35.71% | |
NO | 7 | 25.00% | |
NO.....its not important! | 5 | 17.86% | |
Voters: 28. You may not vote on this poll |
10-23-2004, 10:05 AM | #1 |
I wanna be Dave Join Date: Feb 2004 Location: on a Big Rock
| Bearings in Clod Crawler axles......Yes or No
I can't think of a good reason either way! I don't |
10-23-2004, 12:59 PM | #2 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
| Re: Bearings in Clod Crawler axles......Yes or No
I don't have a clod but I don't run bearing in my TLT axles. Bearing are for high speed cars. You won't notice much of a difference when going at crawling speeds.
10-23-2004, 02:35 PM | #3 |
I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
It is EXTREMELY IMPORTANT!!! I nuked 3 gearsets with the stock bushings. Switched to good bearings, got better run times, less noise and no more nuking gearsets.
10-23-2004, 07:31 PM | #4 |
Newbie Join Date: Oct 2004
grease the shafts and I think bushings are just fine. No chance of a bearing going bad that way.
10-24-2004, 10:07 PM | #5 |
Newbie Join Date: Jun 2004 Location: Spokane WA
I've run bearings in all of my R/C rigs, its cheap insurance. besides it keeps the load of the axle centered in the bearing where as an axle will wear into a bushing causing slop and requiring replacement. What ever you run is your decision, just as long as you run.
10-25-2004, 09:52 AM | #6 |
I have been running my clod axles for the last year with the stock plastic bushings. I have never replaced them. They are starting to show some slop at the outer axles now so they will be replaced soon. Having bushings in the axles has NEVER caused me any problems. My opinion: if you like spending money, put bearings in from the start. Otherwise, run the bushings until they wear out and then replace them, either with more bushings or bearings. |
10-25-2004, 10:50 AM | #7 | |
| Re: Bearings in Clod Crawler axles......Yes or No Quote:
10-25-2004, 11:25 AM | #8 | |
10-25-2004, 06:08 PM | #9 |
bendforthebone Join Date: Feb 2004 Location: Jamul
i still have bushings from when i got it from the swapmeet. The guy i bought it from got it in 1990. I haven't had probs yet!
10-25-2004, 08:12 PM | #10 |
Rock Stacker Join Date: Aug 2004 Location: SAN DIEGO
was it at the spring valley swapmeet?
10-25-2004, 10:02 PM | #11 |
no it was at a swap meet called the big 3 at Qualcom stadium during febuarary like 3 years ago
