04-13-2010, 05:40 AM | #1 |
Newbie Join Date: Mar 2010 Location: Emmitsburg, MD
| Question about shock springs/oil.
My truck came with black bodied/black springs T-maxx shocks on it. After doing a search on them it seems like they a good replacement for the truck. After doing a eBay search for a rebuild kit I ended buying a new gray set with red springs. I put them on but they seem too "tight". Basically when driving it bounces around a lot. To the point it's almost funny. It looks like a mid eighties Monster Truck when it hits anything. Do I need to change the springs or weight of the oil to soften up the suspension some? Granted I'm comparing this to a Mini T, but I've seen T-maxxs and E-Maxxs running and they don't bounce around like this thing does. It almost looks like the original Tamiya videos of the original Clod Buster. Thanks, |
04-13-2010, 12:02 PM | #2 |
Pebble Pounder Join Date: May 2008 Location: Vancouver, Canada
Try a heavier oil, that should slow the travel in the shocks the heavier the slower.
04-13-2010, 12:26 PM | #3 | |
Make sure the shocks move freely where they are mounted to the chassis and links. Does the gray shocks use a piston with the same number of holes as the black shocks? Are you using the same weight oil? Maxx trucks have their weight in the chassis so the shocks are used to dampen the lighter moving suspension. Crawlers and particularly Clod axles have most of the weight in the axles so the shocks do not dampen much when driving around on flat ground. Last edited by Grizzly4x4; 04-13-2010 at 12:30 PM. | |
04-14-2010, 10:12 AM | #4 | |
04-14-2010, 10:38 AM | #5 |
Newbie Join Date: Jan 2010 Location: central
I bought a set of the grey shocks for mine & they have the red springs but with a white dot on them.. The shocks seem fairly stiff (only running 4 not 8 shocks) so Im not sure if the red with white dot are stiffer than the old red springs..I am considering a lighter oil in the shocks to get easier compression..i think the tires are doing more bouncing than the shocks..
04-16-2010, 10:30 AM | #6 |
I should be heading to the LHS this weekend. What weight oil should I look for?
04-16-2010, 01:46 PM | #7 | ||
Are you trying to go fast with this thing or just crawl? Is it a tube chassis or a lightweight TVP design? What size tires and wheels are you running? Are your shocks mounted to the links or the axles? Last edited by Grizzly4x4; 04-16-2010 at 02:09 PM. | ||
04-16-2010, 02:02 PM | #8 | |
