10-26-2004, 02:33 PM | #1 |
Pebble Pounder Join Date: Apr 2004
| can a super rooster
can a super rooster run 2 stock clod motors and 10 cells can a rooster do the same |
10-26-2004, 04:21 PM | #2 |
Rock Stacker Join Date: Jun 2004 Location: Central, Ok
| Re: can a super rooster
The Super Rooster is rated up to 10 cells, and dual 15 turn motors in parallel. So yes, it will handle what you stated. The Rooster on the other hand is only rated up to 7 cells, and dual stock motors at the most in parallel. So, no the normal Rooster would not handle what you stated. |
10-26-2004, 06:19 PM | #3 |
will the rooster handle two clod motors with 6 cells or 7 cells
10-27-2004, 03:55 PM | #4 |
It will handle 2 stock motors in parallel. I would say no less than 22 turn motors.
10-27-2004, 04:10 PM | #5 |
The Rooster will handle 2 stock motors or 2 lathe motors in parallel with 6 cells. It will werk with 2 Magnetic Mayhems but you will need a receiver battery pack. It does get pretty hot with the MM's but mine never shutdown. http://www.rccrawler.com/posts2316-0.html |
