03-30-2006, 07:03 AM | #1 |
Newbie Join Date: Sep 2005 Location: Lubbock
| Clod front servo mount?
If any of you have dimesions on servo mounts please post. I have searched the forum and have not found much. If you know of something point me in the right direction. I am looking for the mount that puts the servo vertically on the diff.
03-30-2006, 12:58 PM | #2 |
Quarry Creeper Join Date: Feb 2006 Location: Shillington
I can send you some pictures of one I made from a peice of aluminum plate. It mounts on the axel brace....
03-30-2006, 01:44 PM | #4 |
SMR that is the one I am looking for now I need to find dimesions on that plate I don't need the links. Why pay 60 when I can make my own. If no one has dimesions that is cool this is a good start.
03-30-2006, 05:22 PM | #5 |
Rock Crawler Join Date: Jan 2006 Location: PNW!!!
| I just measured the length from end bracket to end bracket on the servo and it measures 2 1/8inch. That should be a good start if your thinking of fabbing a plate. |
03-31-2006, 06:34 AM | #6 |
SMR can you give me a dim. from front to back? Do you have a profile view of the plate? Thanks to you guys for posting info.
03-31-2006, 10:16 AM | #7 | |
The plate for my NN is your typical servo laid over the axle brace type. Good Luck Mike Last edited by SMR4RUNNER; 03-31-2006 at 10:29 AM. | |
04-03-2006, 07:08 AM | #8 |
Thanks SMR.
04-06-2006, 04:38 PM | #9 |
Rock Crawler Join Date: Mar 2006 Location: Holiday, FL
You Don't Want The Plate That Mounts It Like That Just Get Some Servo Mounts For A E-maxx And Mount The Servo To The Axle Brace Some What Like Rc-guys Pro Steering Kit.
04-06-2006, 05:07 PM | #10 |
It's better to mount it like this. Contact The Crawler Store here in the vendors section. |
04-06-2006, 07:10 PM | #11 | |
Quarry Creeper Join Date: Sep 2005 Location: VARCOR
Use Traxxas #2715 servo mounts. These work perfect Quote:
04-07-2006, 09:14 AM | #12 |
Newbie Join Date: Mar 2006 Location: Yankton
Scooter what model are those from? I have found a nice pair of servo mounts for the jato that look like they might work but cant find a parts list!
04-08-2006, 02:28 PM | #13 |
| Traxxas Part #2715
Those Servo Mounts Are For 2.5 4-tec It's What Mounts The Steering Servo |
06-09-2006, 07:30 AM | #14 |
Quarry Creeper Join Date: Mar 2006 Location: ft. collins
I see opinions for both the axel mounted and for the gear case mounted methods. I am considering purchasing the gear case style due to the fact that it seems the twisting force caused by the servo, ends up loosening the axel brace screw. I have the RC4WD axel brace with the servo platform and the screw loosened up again. Here is a picture of the setup. Has anyone had this issue and are there suggestions for a fix? Thanks. |
06-09-2006, 08:05 AM | #15 |
Rock Stacker Join Date: Jan 2004 Location: Morgantown
The mount that mounts it verical looks good but it kills your approach angle and will eventually damage your servo.
06-09-2006, 07:50 PM | #16 |
Pebble Pounder Join Date: Mar 2006 Location: hillsboro
I have the same problem with the mount loosening up. The combination of torkie servos and high articulation loosens the bottom axle stay bolt, thus in turn causing it to pivot and loosen the top screw. I now use a longer bolt with a nylock and loctite to hold the bottom of the axle stay and bottom suspension link. |
06-09-2006, 09:31 PM | #17 |
Rock Crawler Join Date: Apr 2006 Location: louisville
the axle stay is the best place but like most say it can loosen the bolts over time my trick is to paint the nut and threads with clear nail polish
06-10-2006, 06:38 AM | #18 |
HERES what i bought ya cant beat the price... nice peice too http://www.crawfordperformanceengine...R1&log_pid=yes even came with the mounting hardware! |
06-11-2006, 04:39 AM | #19 |
Newbie Join Date: Nov 2005 Location: australia
| Try these worked for me on standard susp |
06-12-2006, 11:22 AM | #20 |
RCC Addict Join Date: Nov 2005 Location: Saving for Nationals!!
Here's what worked best on my rig... |
