Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Clod Buster
Thread: home built clod chassis completed
Old 04-27-2006, 06:05 AM   #1
Default home built clod chassis completed
swapped out the jades for some 27t stockers
locked diffs f/r (thanks pyro62-ebay)
mgt wheels and cut tires (my now sold mgt)
jj's wideners
savage shocks
green socks (you gotta love these things.)
hand made chassis (nn copy) (lowes)
.25 in. solid links w/traxxas ends (htusa)
17 in wb
4 in. chassis clearance
85 deg. +/- articulation (limiting strap in front)
11t pinions (slotted cases)
jr 3xs radio rs310 rec.
envious8420 is offline   Reply With Quote
Old 04-27-2006, 09:15 AM   #2
Looks Good, thanks for giveing the NN credit for the design, any action shots.
Magic is offline   Reply With Quote
Old 04-27-2006, 09:36 AM   #3
[HOONIGAN]
Wrecker's Avatar
cool, looks like you did a pretty good job of getting it like a NN.
Wrecker is offline   Reply With Quote
Old 04-27-2006, 10:16 AM   #4
RIP Buster
badger's Avatar
I changed the title of this thread.
If it's not an actuall NN from thecrawlerstore.com don't use the name.
badger is offline   Reply With Quote
Old 04-29-2006, 01:13 PM   #5
ok. my bad.
Old 04-30-2006, 07:50 AM   #6
loooks nice man, how much did it all cost?
Crawler Noob is offline   Reply With Quote
Old 04-30-2006, 08:31 AM   #7
You might want some lathe motors and pinion adapter in it. It's going to be really fast as it sits.
Cole82 is offline   Reply With Quote
Old 04-30-2006, 09:01 AM   #8
yeah i picked the lathes up yesterday. what a difference that made.
all told electronics and everything included about $100
Old 05-01-2006, 06:34 AM   #9
lathe motors make this truck almost unstoppable. what a difference.
when i first built this i was running 15t jades -fast but no torque 5-7 min run times
then i switched to 27t stockers. these seemed as bad as the jades for crawling. 7-10 min. run time.
55t integys- awesome 35-45 min run time.
and this is on a 6 cell 3300 matched pack with 1.19 numbers
what a difference.
Old 05-01-2006, 11:59 AM   #10
lookin good. how do the mgt tires work for ya?
Crawlsalot is offline   Reply With Quote
Old 05-01-2006, 01:14 PM   #11
i like them alot.
thinking about pulling them apart and trimming up the foams a bit.
