Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: How to achieve max steer out of stock axles
Old 06-02-2011, 12:55 AM   #1
Default How to achieve max steer out of stock axles
So as of now I run complete bone stock axles with the tires. I run the NN chassis on my rig. I know to cut the plastic stoppers on the top and bottom of each knuckle to allow the servo to have more throw. But still doesn't seem to be enough for crawling.
I would rather run a narrower tire than using offset spacers for the wheels.
Any other tricks to get a sharper steering angle? Or am I stuck until I buy sum aluminum knuckles and CVD axles to gain sharper turning degrees?
Rok Krawl is offline   Reply With Quote
Old 06-03-2011, 02:37 PM   #2
You can also grind off the ring on the back side of the knuckle to get a little more. The stock axels will only turn so far before they bind up and eventually snap.
ThunderVP is offline   Reply With Quote
Old 06-20-2011, 09:47 AM   #3
How much additional steering if any do you get from the CVDs?
jetroc0088 is offline   Reply With Quote
Old 06-23-2011, 12:23 AM   #4
You can gain quite a bit of durability/steering throw by using thundertech CVD's. Once you start really dropping money into the clods via CVD's, metal housings, gearsets look into super bullies. It's tough to turn our backs on such a reliable axle but decisions have to be made.
I am still miking Clodbusters w/ cvd's and all alum upgrades.
Try to find used parts for the axles. IT will make it a lot easier.
xgerstandtx is offline   Reply With Quote
Old 06-24-2011, 11:15 AM   #5
SMR4RUNNER's Avatar
You can increase uber steering by modifying your knuckles for zero ackerman. However without upgrading to alum knuckles & CVDs, the plastic knuckles will only handle so much stress and the stock axle pins will shear off due to the excessive turn radius.
Here is an example of the mod on my clod axles;
SMR4RUNNER is offline   Reply With Quote
Old 06-24-2011, 08:04 PM   #6
Do you have another pic of the other side? How did you attach the ackerman piece to the near side of the knuckle?
Thanks
lud98r is offline   Reply With Quote
Old 06-24-2011, 11:45 PM   #7
Thanks for the pix. But after buying 60 bux worth of knuckles and the alumn axle tubes it would be cheaper for me just to buy a set of rc4wd bully axles that are complete. But who knows.. may just have to get the alumn knuckles for now as I having to replace burned up ESC and bought external BEC. And to top it off building custom tires.
Old 06-25-2011, 09:39 AM   #8
Thanks
yes, pics of the underside please...thanks...
nosyajg is offline   Reply With Quote
Old 06-25-2011, 06:33 PM   #9
Stock axles will give about + - 25° max
The TTR CVDs will give about + - 40° max
Old 07-20-2011, 09:10 PM   #10
How does that compare to giving up the ghost on the Clod axles and doing the previously mentioned Bully Axles?
jl0r is offline   Reply With Quote
