Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Clod Buster
Thread: Clod build 1.0
Old 05-06-2006, 06:48 PM   #1
Default Clod build 1.0
took some of the advice i found on the forums and this is what i have so far. I just have it built up to mess around with. Not totaly finished yet. Other upgrade coming as soon as i get some cash i.e. bumpers/skid plates, 9 tooth pinions/adjustable motor mounts, a body, clod to maxx adapters, and 4 wheel steering just to name a few.
65t lathe x2 (Integy)
locked front and rear (rc4wd.com)
axle wideners (Inetrc.com)
Wheel adapters (thanks Bender)
Rockbull II chassis with strait LCA's (rc4wd.com)
Metal rod ends (rc4wd.com)
C-Hub braces (rc4wd.com
Traxxas EVX ESC.
Dual 3600 mAh Venom batteries
JR XS3 with JR 310 reciever
Savage Piggy back shocks (Integy)
Cheyanne 40 series Beadlock wheels (Proline)
40 series Moab's (Proline)
Thaadius is offline   Reply With Quote
Old 05-06-2006, 07:38 PM   #2
Most of it looks pretty good!!
But, it is WAY too tall, and has way too much articulation. Other than that, it looks capable.
Robb is offline   Reply With Quote
Old 05-06-2006, 08:07 PM   #3
OCCUPY RCC!
dezfan's Avatar
I agree, change to a set of shorter shocks, that will lower you ride height and limit the articulation. Looks top notch! Can't wait to see it finished!
dezfan is online now   Reply With Quote
Old 05-07-2006, 12:19 PM   #4
i had the shorter t-maxx shocks on it and wasnt satisfied with the articulation. went with the longer shocks to achieve 90%. i agree with the ride heighth tho. as for the chassis im satisfied with it atm. im not into hard rock crawling (competition) yet. im sure the NN is an awesome chassis but im also going for a "cool" look.
Old 05-08-2006, 09:30 AM   #5
artic is plenty at 60 degrees.
DirkDigler is offline   Reply With Quote
