| | #1 |
| Rock Stacker Join Date: May 2006 Location: Surrey
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Mar 2006 Location: Bedias, Texas
| Looks good so far other than the fact you may have a little too much weight up high on the chassis. Love the tires, if you ever decide to sell them off let me know. |
| | #3 |
| Newbie Join Date: May 2006 Location: Peoria
| Looks nice, I have the same chassis, but I took off the lower level and bolted the connecting rods directly to the main level. |
| | #4 |
| Pebble Pounder Join Date: Mar 2006 Location: hillsboro
| Get some center top link posts for the diffs and place the top links on them. And relocate the top links chassis attachment point to the next set of upper holes. Then place the the lower links in the holes on the chassis that the top links were once placed. I would place the lower links to the axle on the top knuckle for more ground clearance. But this is up to you and related to how much wheel base you have, shock mounting and heigth of the upper link mount you use. I did a similiar build with my clodzilla II chassis. |
| | #5 |
| ~The Scale Shop~ ![]() Join Date: Apr 2006 Location: KILLEEN TX
| im confused? no upper links? |
| | #6 |
| | #7 |
| Just thought about it , but for the top link mounting you will need to redrill those upper holes. Further out board than the lower link moutning holes. |
| | #8 |
| i think the holes could stay, i tried the setup and i could get about 80 degrees of articulation, and even if i screw up, i could easily fix it later... |
| | #9 |
| Rock Crawler Join Date: Apr 2006 Location: louisville
| dont look bad so far id like to see it finished and are you gonna paint the frame or leave it bare |
| | #10 |
| Newbie Join Date: Feb 2006 Location: D-town
| looks sweet |
| | #11 |
| i will leave the frame bare... my LHS is slow... still waiting for the order of parts.... |
| | #12 |
| | #13 |
| Rock Stacker Join Date: Mar 2005 Location: Wethersfield, Connecticut
| wow that thing is looking awesome. Too much articulation though. |
| | #14 |
| RCC Addict Join Date: May 2006 Location: USA
| i like the tires/rims. i was always a fan of the stock white wheels, reminds me of bigfoots wheels. looks good so far dude. |
| | #15 |
| should i get a body? probably 1/8 to fit the rollcage, any suggestions? BTW got the Moped in the mail today... ahhhh... good day Last edited by Techball; 06-07-2006 at 12:33 AM. |
| | #16 |
| body is up to you how long is it id make a bigger taller cage make it look like a tubelar one or just take it off and run a body |
| | #17 |
| | #18 |
| just going to add that i will be running Lsts on X-75 because im getting the Rcguy adaptors and the 4WS will be off a y harness and mounted vertically on the gear case due to my special lower mounts positions, comments will be helpful, thanks, :-P |
| | #19 |
| | #20 |
| Thread Tools | |
| Display Modes | |
