06-17-2006, 08:15 PM | #1 |
Rock Stacker Join Date: Dec 2004 Location: Antioch
| 60/40 or 50/50 ?
I'm designing my chassis. I've been debating in my head weather to design it as a 60/40 chassisor a 50/50 chassis. I know I can just mess with the link length later. However If I can design the chassis to cater to the 60/40 I could make the suspension work better. So who is running a 60/40 chassis?Is it worth it to put the time into doing this? the weight is forward more where we need it I can put the Speedcontrol on the front axle to lower the weight a little more. |
06-17-2006, 08:45 PM | #2 | |
06-17-2006, 08:54 PM | #3 |
Thats what I have been leaning toward. Less hassle with having to make battery packs to fit on axles to get the weight distribution right. I imagine the rig will act more like a 1:1 scale rig as well. All I've ever had as far as rc rigs is a nylint 1:6th jeep. |
06-17-2006, 09:46 PM | #4 |
So I'venever seen an actually seen a crawling chassis in my life.... How long is an NN chassis plate at it's longest and shortest points? I'm not going to copy the chassis. I just need an idea of the measurements so I can make my side plates. I'm using solidworks to draw it up that way I can easily print out a 1:1 scale copy to stencil onto the aluminum. SO far I have made two seprerate center points on the drawing the 50:50 center point and the 60:40 center point. this will allow for the 60:40 calcs. for tyhe links and a 50:50 based point for mounting the shocks. |
06-17-2006, 11:27 PM | #5 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
go to orcrc.com and click tech, there should be something in there.
06-18-2006, 04:09 PM | #6 |
Didn't find anything on that link. But after a few too many beers I locked my diffs. modded the nylint wheels and mounted my pinions, motors and adapters. I set everything where I wanted it and measured. I underestimated on my side plate material. so now I need to get another small sheet of aluminum. Got one side plate drawn out I just need the other peice so I can cut it all out. I've cut and tapped the aluminum rods that will attach the two side plates. found and cut my CJ-8 body and then I organized all the crap I had spread through out the room. I'm well on my way to having a 60/40 chassis,or something close to that ratio. I need to order a few more things and this rig will be done. I wish my full size rigs could come together this quick. |
06-18-2006, 06:02 PM | #7 |
Hell's Gnome Join Date: Jun 2006 Location: I'm mean because you're stupid.
My 60/40 is a geko-I chassis with 7.25" links in the back and 6" links in front. Not sure if it's an exact 60/40 split but looks it to me. Works great, and if I want 50/50 I just put the other set of 7.25" links on the front and it's there.
06-18-2006, 08:30 PM | #8 | |
Can you tell me what seperarion is between the front and lower links on the chassis. This will help me with making my links. I can'y get the chassis plates done yet but if you got me the measurement I could use it to determine my links length for my chassis. | |
06-18-2006, 10:42 PM | #9 |
doesnt matter, i found this out the hard way, every body on another forum bitched it to me! the 60/40 thing says tlt because they think real crawlers should have axles or be a stick.
06-18-2006, 10:45 PM | #10 | |
06-18-2006, 11:17 PM | #11 |
A real crawler is full size.. to me |
06-19-2006, 10:06 AM | #12 |
i like both types, direct drive and shaft. i just dont have the money to get a shaft right now, if i did it would be a txt because i like things big!
06-19-2006, 06:48 PM | #13 |
i've always wanted to build up a bruiser/Hilux rig.
06-19-2006, 08:02 PM | #14 | |
Quarry Creeper Join Date: Apr 2006 Location: Cincy
| 2" with Clod Axles... Quote:
06-19-2006, 09:28 PM | #15 |
Just like the real thing only smaller. I'm used to being able to weld link mounts wherever I need to on a full size axle. |
