12-15-2004, 11:00 PM | #1 |
Rock Crawler Join Date: Dec 2004 Location: www.ORCRC.com
| Mounting 7.2V battery on axles.
I've got my servos mounted inbetween the motor and axle so that lleft me a lot of room on the front face of the front axle and the rear face of the rear axle. Is there enough room to mount a 7.2 battery there? I know that sounds like a stupid question but batteries are on order and I can't seem to find any C-cells around the house to mock it up. I think there is.... I have to assume someone has done this if it actaully fits. Anyways on my tuber build I'm really thinking about doing this for that ultra low COG! |
12-15-2004, 11:21 PM | #2 |
| Re: Mounting 7.2V battery on axles.
yeah, it fits just fine. your drawing is almost perfect actually.
12-16-2004, 12:01 AM | #3 |
Pebble Pounder Join Date: Jul 2004 Location: SOJO
| Re: Mounting 7.2V battery on axles. |
12-16-2004, 09:56 AM | #4 |
I wanna be Dave Join Date: Jan 2004
yeah! Who need approach angles anyway!!!!!??? |
12-16-2004, 10:45 AM | #5 |
How would it afftect approach angles? It still would be behind the leading surface of the tires and I was thinking of mounting it no lower than the axles tubes.
12-16-2004, 03:32 PM | #6 | |
I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
| Re: Mounting 7.2V battery on axles. Quote:
I've mounted mine on the bottom side of my upper links before, worked fairly well. | |
12-16-2004, 04:35 PM | #7 |
So is it better to mount them high on the axles or low in the center of the chassis... ? Lets assume both those locations put the battery the same hieght off the ground. If they are in the chassis then "I think" during a climb more weight will be put over the rear tires. But if the battery is on the axle then won't that provided more weight to each axle? Thats what I was thinking. Just trying to spread the weight out more all over the rig instead of having all the weight in one central spot. I have no idea which which better, so thats why I'm asking...... |
12-16-2004, 05:32 PM | #8 |
Newbie Join Date: Oct 2004 Location: Yakima, WA
Think about when your rig is climbing a steep obstacle. Think about how high the weight of the battery is going to be if it is mounted on the front axle. Now think about how high the battery weight is if the batt. is mounted low in the chassis. IMO, battery low in the chassis keeps the CG low even when climbing something steep.
12-16-2004, 11:06 PM | #9 |
Pebble Pounder Join Date: May 2004
Rick, Josh just ordered new batt.s also, so if you want my old one, call my cell tomorrow and I'll bring it over tomorrow. Jeff |
12-16-2004, 11:33 PM | #10 |
Yeah, I might just have to borrow that one from you.
12-16-2004, 11:51 PM | #11 |
Quarry Creeper Join Date: Dec 2004 Location: Tampa, Fl
Lets see your pics of your servo mounts. what made you decide to put'em there instead of on the axles?
12-17-2004, 08:09 AM | #12 |
Pictures of them are here: http://www.rccrawler.com/postx4473-0-15.html I did it because I can...... also it cleans up the front face of the axle and since I running dual batterries, This location would be a good spot if they fit and don't interfer with the tires or obsticles. |
12-17-2004, 12:13 PM | #13 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
12-17-2004, 01:22 PM | #14 |
Are you runnigg dual batteries? If so, how do you like the balance compare to a chassis mounted battery?
12-17-2004, 04:18 PM | #15 |
RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
If you do decide to mount your battery like that, make sure you have a thick, beefy skid plate in front of it, because you will bash the FUDGE out of it.
12-18-2004, 12:07 AM | #16 |
Well heres what I came up with so far for the rear axle..... I think its going to turn out sweet! |
