07-07-2006, 10:08 PM | #1 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
| will these wheels fit the clod http://www2.towerhobbies.com/cgi-bin...?&I=LXJYL8&P=7 will those wheels fit the clod (stock mounting hub i think, i dont have the car yet) it will be for my 1st crawler but it comes with stock clod wheels and tires, if those wheels in the link dont fit can anyone let me know what wheels will or what i'd need to get them to fit? that would be awesome i couldent fint anywhere that said what the stock hub size was on the clod cause i want to run these tires http://www2.towerhobbies.com/cgi-bin...?&I=LXMCZ5&P=7 and what would you recomend, foams or no foams, cutting the foams seems kinda dumb to me. thanks again, i look forward to crawling |
07-07-2006, 10:40 PM | #2 |
Rock Crawler Join Date: Dec 2005 Location: Mesa
12mm on the stock clod hex so you will need some adapters for the Savage/T-Maxx wheels which should be a 14mm. From what I've seen, you'll need adapters for about everything bigger than 2.2 wheels. Imex does make rubber for the stock clod wheels though. Spend some time going through the Tires and Wheels section. There's some good info about running foam inserts. |
07-07-2006, 10:48 PM | #3 |
doh'! completely forgot aobut that section, thanks though.
