07-22-2006, 10:06 PM | #1 |
Pebble Pounder Join Date: Apr 2006 Location: meriden
| motor wiring...
how do i wire the motors with the evx esc? kinda confused since everyone says to wire the motors in parallel or something like that, but the evx esc is built to hold 2 motors... what do i do? can someone show me how to wire this...pictures are probably the best way to show be... Last edited by insane; 07-22-2006 at 10:37 PM. |
07-23-2006, 11:26 AM | #2 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
Use the search button, there's a pic around here somewhere...
07-23-2006, 01:27 PM | #3 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
With the EVX, it's simple... The rear motor has to be wired backwards in relation to the front one, but other than that... red to +, black to - on the front, black to + and red to - on the rear... That's how mine is with Deans in between....
07-23-2006, 05:53 PM | #4 |
so its connected parallel internally...inside the esc... |
07-23-2006, 09:19 PM | #5 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
no, its in the wiring. you split the wire coming out [ esc ]:---<:: split |
07-24-2006, 08:56 AM | #6 |
With the EVX, you DO have to wire the rear in backwards... But yes, inside the EVX it is parallel... The reason why you have to wire the rear backwards is because the E-MAXX uses both motors turning the same way... Clod's don't.. One goes one way, the other, opposite... |
07-24-2006, 08:05 PM | #7 |
I wanna be Dave Join Date: Jul 2006 Location: Moscow Mills MO
not trying to hijack your thread.......but........I jumped the plug to run just one pack off my EVX and it is slower(weaker) than my super old airtronics contender ESC???
07-25-2006, 06:58 AM | #8 |
right, because it was built for 550 size motors, and 14.4 volts... by jumping it, ur putting 7.2v or half of the required. and then splitting it to 2 motors... |
