07-27-2006, 12:22 PM | #1 |
Rock Stacker Join Date: Jul 2006 Location: Elizabethton,TN
| bringing out the clod,questions
i getting ready to get the clod, out its stock, i'm looking to use this mainly as a yard basher. havin not really used it what are the things i need to foucus on,ie what breaks first this way what needs improving etc thanks |
07-27-2006, 12:32 PM | #2 |
Quarry Creeper Join Date: Apr 2006 Location: winchester
well stock I have know clue what breaks first i locked my clod diffs with krazy glue and have had no problems @ all i cant think of any other clod parts that im running did i read your post correct you have a stock clodbuster and your yard bashing it? what breaks first or do you mean yard crawling |
07-27-2006, 12:39 PM | #3 |
i'm just gonna use it to bash it the yard, and its all stock
07-27-2006, 12:50 PM | #4 | |
at all!!!! these things are tuff i remember now when i got my original the links were snapped but who knows what the last person who had it did with the thing the truck axles ( which is all that i needed) r used from the old 80's clod i picked up for 30 bucks which im talking about above and there were no plastic chips or anything like that wrong with the inside of the axles. bash the h e l l out of it | |
07-27-2006, 08:55 PM | #5 |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
Lots of stock Clods will break the lower shock mounting points off of the suspension arms. If you've got an original Clod (from the 80's or early 90's), then you may also have problems cracking the chassis where the suspension arms mount to the center of the chassis. Super Clod kits came with metal chassis stiffener plates that helps prevent this from happening. You'll also find that the stock steering system is something less than perfect. You may want to upgrade that to an aluminum steering kit that provides much better steering response. You can still use all the stock steering parts, this kit just replaces the plastic servo savers mounted on the gearboxes. We offer this kit to correct that problem: http://www.crawfordperformanceengine...R2&log_pid=yes Enjoy running the truck around, and if/when you decide to upgrade parts of it, this is the place for building some great rock crawlers! Good luck! |
07-27-2006, 09:17 PM | #6 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
my rotation bracket broke easily, get the aluminum ones from rc4wd.com. http://rc4wd.com/shop/product_info.p...roducts_id=873 youll need to order 2 of these. |
07-28-2006, 01:13 AM | #7 |
Rock Crawler Join Date: Apr 2006 Location: louisville
on a stock clod 2 things suck the steering and the speed controler
07-28-2006, 07:03 AM | #8 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
CPE MT, you're exactly right, those are the only two things that ever broke when mine was stock. But as andrewmp6 said, the speed controller sucks. |
07-28-2006, 07:14 AM | #9 |
well stock other than speed control cpe i'll look into those, clod those too. thanks for all the help
07-28-2006, 07:30 AM | #10 |
i would recomend not buying from rc4wd im still waiting on link mounts that i ordered almost a month ago search for the parts you need hobbyetc.com has all kinds of stuff cheap and with fast shipping |
