07-31-2006, 10:40 PM | #1 |
Pebble Pounder Join Date: Mar 2006 Location: hillsboro
| clod axle shafts
I am thinking of upgrading my axle shafts an need some input. I have not broke an axle shaft yet, but it will happen. I am upgrading to front and rear wheel steer and want to compete in the future. But I am debating on thundertech racing shafts or 303 steel axles from rc4wd. I already have offset maximizer rims on 3/4 ACE mfg. adapters. So I dont want to space the tires any wider. Are both axles comparable in strength? If not, Should I ditch my offset rims and or spacer adapters and go for the thundertech shafts. That would mean getting new rim faceplates with no offset and possibly rc4wd t-maxx wheel adapters. |
08-01-2006, 12:55 AM | #2 |
Rock Crawler Join Date: Apr 2006 Location: louisville
id guy with the thunder racing ones i love rc4wd parts but sometimes you gotta wait a while to get them and rcguy.com has adaparts for the maximizer wheels they clam they dont add any offset its up to you its your money
08-01-2006, 07:44 AM | #3 |
Rock Crawler Join Date: Nov 2004 Location: Driving the Troysion Stick up the BIG BOY line!
If you are broke and have no money the RC4WD ones are better than stock, but in my opinion, save your money and get the thundertech CVDs nothing can compare. I've had both so I know.
08-01-2006, 07:56 AM | #4 |
Pebble Pounder Join Date: Mar 2006 Location: Milan, IL QCA (rural)
THUNDERTECH CVD's.... better turning radius capabilities than stock
08-01-2006, 10:04 AM | #5 |
Keep your wheels and Heydco adapters and get the Thundertech CVDs from The Crawlerstore.
08-01-2006, 01:08 PM | #6 | |
08-01-2006, 01:47 PM | #7 |
Whoops I forgot that the axles widened the track. I'd get rid of the wideners and keep the wheels. Ace made himself and me a set of thin 12mm to 14mm adapters. PM him and see if he'd be willing to make some more. |
08-01-2006, 03:19 PM | #8 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
I would save up for the TTR CVD's and get some RcGuy wheel adapters. They're super thin, cheap, and should make the width of your truck perfect |
08-01-2006, 07:17 PM | #9 |
Quarry Creeper Join Date: Jun 2004 Location: Ventura
do bender's 23mm wheel adapters work with the thunder tech axles. (P.S. did anyone else notice these aren't constant velocity joints) |
08-01-2006, 07:58 PM | #10 |
Rock Stacker Join Date: Mar 2004
I run the rcwd 303 now.I've broke two thundertech cv's already
08-01-2006, 10:01 PM | #11 | |
08-02-2006, 03:59 AM | #12 |
i think he broke the joint in them thats the only thing i see you could ever break i forgot about the thunder racing ones widen your truck the rc4wd ones are the stock ones just made out of stronger metal
08-02-2006, 12:26 PM | #13 |
I'm running 40 series moabs.I running the rc4wd ones.They have less parts and don't widen it like ttr.Thats seems to stress them with bigger tires
08-03-2006, 11:25 AM | #14 | ||
What do you mean they aren't CVD's? They look exactly like any other CVD I've owned? Quote:
You're either running some seriously offset wheels or throwing your truck off cliffs. I know of two people that have went back to stock pieces after using the RC4wd axles because of poor tollerances and I've yet to hear any complaints out of the TTR stuff. Don't the TTR's come with a lifetime warrenty? | ||
08-03-2006, 11:30 AM | #15 | ||
