08-04-2006, 12:31 PM | #1 |
Rock Crawler Join Date: Jan 2005 Location: Windsor, VA
| New help with link setup
I have searched and searched and searched. I have built two different chassis, one a tuber and one a vertical plate. I keep having a problem with the rear end driving under the front when I am turning, the inside front tire will lift off the ground, and if I keep going, the front axle will actually flop over. I assume that I don't have my link geometry right. What I want is some measurements from someone's chassis that works. I want to know how far apart your link mounts are vertically and horizontally, and how long the links are. Also, are you mounting them to the top or bottom bolt hole on the kunckle? Any help would be greatly appreciated. thanks, Michael |
08-04-2006, 01:23 PM | #2 |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
Do you have a photo of your current 4-link set-up you can provide here?
