Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: Thunder Tech Axle ?
Old 05-09-2007, 07:43 PM   #1
Default Thunder Tech Axle ?
Thunder Tech Axle ? I have stripped a set of the molded plastic Straight axle drive hexes, does anyone make a set that is metal of any kind for a replacement? Any help would be appreciated, Thanx.
tyerfryersc is offline   Reply With Quote
Old 05-09-2007, 07:53 PM   #2
Can you post a pic of what you stripped?
RCCrawlerTT is offline   Reply With Quote
Old 05-09-2007, 07:56 PM   #3
Default Plastic drive hex.
It's the end of the TTR Straight axle kit the drives the wheel. Like the Splined brass hex on a stock clod stub axle. People thet have the TTR straight axle will know what I'm tallking about.... I hope. It's the only plastic part on the kit. Which I think is kinda dumb, but I bought it anyway.
Old 05-09-2007, 08:28 PM   #4
Its the wheel hub part on the outer end of the shaft. I would call TTR and see what they say about it, they'll prob send you more for free.
nosduj is offline   Reply With Quote
Old 05-09-2007, 09:07 PM   #5
Yep, I have stripped a few of them myself. Try contacting TTR and see if they will start making Alumn one. Other then that. Change over to 14mm. I'm changing my 2.2 Over to 14mm as we speak. I'm tried of dealing with 12mm's.
Old 05-09-2007, 09:31 PM   #6
What sucks is that they used to be aluminum, the plastic ones are the third gen.
They've got progressively weaker as the production has gone on. The originals had steal inner hexes, and I believe aluminum outers. The second gens like I had used the stock brass inner hexes which strip quite often under brushless power and aluminum outers, they do steer tighter than the first gens by I think 5 degrees though. The third gens use the stock brass inners and the crumby plastic outers and steer the same as the second gens.
I guess TTR is trying to improve the profitability of their product.
Highmark is offline   Reply With Quote
