Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: shock setup
Old 08-13-2006, 03:07 AM   #1
Default shock setup
Hi Im new in rock crawling and I have a I-Rock from INERBEECREW. My question is what springs and oil should I use. Soft springs and thin oil? I have no clue. Maybe some in here have a I-rock and can give a noob from Norway some good advise
peace out
BirdHouse is offline   Reply With Quote
Old 08-14-2006, 12:50 PM   #2
Experiment. I use heavier oil, 60 wt. I use medium springs with some preload dialed in. It will depend on your setup and weight of yout rig. Try different setups till you find what you like.
dystance is offline   Reply With Quote
Old 08-18-2006, 11:23 AM   #3
Listen to what dystance said, i use the same stuff, it works nicely for me, fair articulation
CRUSHER1 is offline   Reply With Quote
