08-17-2006, 11:38 AM | #1 |
Pebble Pounder Join Date: Apr 2006 Location: meriden
| To get more...
to get more steering outta the stock clod axles, i shoud cut off the steering stops. But are there, if any, bad effects from doing this? Like the tires hitting any of the suspension components...the chassis is the NN chassis. |
08-17-2006, 11:58 AM | #2 |
Quarry Creeper Join Date: Mar 2006 Location: ft. collins
I run the NN, and have had no issues with Red Rocks or Moabs.
08-17-2006, 12:18 PM | #3 |
no that not what im trying to get at...today was the first day of testing the nn, and i checked the steering and was expecting alot more than i got...i figured id ask if there were any negative effects to shaving the knuckles before i actually did the mod....
08-17-2006, 01:16 PM | #4 |
Rock Stacker Join Date: Apr 2005 Location: waconia
it kinda of depends on what tries tour running and what kind of stearing linkage you use. I have narrowed moabs with on axel 4ws and i dont have any issues. Tho before i narrowed the axels i did get some rubbing. you can adjust how far you want it to push tho by setting up where your linkage connects on the servo arm.
08-17-2006, 02:22 PM | #5 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
dont shva e those tabs off!!!!! with the stock axle, past a certain turning point the stubs will come out of the axle causing problems... some guys in the TXT forum tried this and ended up having to make limiters for the steering. save up some money and get those Thunder Tech axles... those things turn like cazy!!! Just got em installed on my rig... awsome investment... tough too. So dont mess with those stock hubs... your just polishing a turd.
08-17-2006, 09:12 PM | #6 |
hhhmmmm.....so y do people do it, and what does everyone else get for steering with an unshaved knuckel??? also i looked for those thunder tech knuckles, and couldn't fint them, do u think u could post up some pics of how much they improve the steering? |
08-17-2006, 09:28 PM | #7 |
Quarry Creeper Join Date: Jun 2005 Location: NOrthern Cali
do you have 4ws?
08-17-2006, 09:30 PM | #8 | |
RCC Addict Join Date: Aug 2005 Location: VARCOR
08-17-2006, 10:32 PM | #9 | |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
yeah, it can have some bad effects such as Quote:
08-18-2006, 09:32 AM | #10 |
now would i get the same effect if i trimmed the axles tube steering stops a bit, rather than shaving the knuckles?? and yes, i wam running 4ws... |
08-18-2006, 11:08 AM | #11 |
Quarry Creeper Join Date: Feb 2005 Location: Wheeling
I trimed the stops of the knuckles and the tubes. I have never had a problem with the axles poping out.
08-18-2006, 02:08 PM | #12 |
k now im confused |
08-18-2006, 10:10 PM | #13 | |
Why? Trimming the stops off the knuckles is the oldest trick to gaining a bit more turning on a Clod, Jugg or TXT axles. Sure you can push them too far but 99% of rigs are fine. I did it on my Jugg2 and on the Clod. No issues. You have to do it if you jump up to the CVD's though.... trim stops plus much more of the knuckle and part of the axle tube ends. Best $33 I have spent so far on the CLod. | |
08-19-2006, 11:30 AM | #14 | |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
http://www.thecrawlerstore.com/geartrain.html | |
08-19-2006, 01:13 PM | #15 |
NO offence, but im not stupid, im lookung for the thunder tech knucles, not the axles. i already ordered those.... |
