08-18-2006, 07:28 PM | #1 |
Newbie Join Date: Aug 2006 Location: morrill
| priecs cheep
hay i want to build a crawler chassi for less that 50 dallers i have the links for it and shocks off of a rustler so plz help me build one for less than 50 dallers
08-18-2006, 07:36 PM | #2 |
So you need just a chassis? Do you mean just the center section as far as the mounts for the links and shocks, etc....? Do you have minor hand tools like tin shears and a drill? How about a tap and die set? A Dremel? I built this chassis with 3/32" aluminum sheet that I was able to cut quite easily with tin snips, then drilled the holes, and used the Dremel to spiffy it up. Then I used 1/4" solid aluminum round stock cut to lengths and then drilled the ends out a bit so I could tap them out to fit some 6-32 hardware...these act as the spreaders between sides. All together (since I didn't have to buy any tools), I spent only like $12 on the material and the hardware for the spreaders. Just have to make a design that looks good to you. |
08-18-2006, 07:38 PM | #3 |
Quarry Creeper Join Date: Jun 2006 Location: boondocks
i got a pretty much ghetto home made chassis i made with spare metal and stuff, search my name, you'll find my thread...if youd want it, $25shipped..possibly $20
08-18-2006, 08:51 PM | #4 |
Rock Crawler Join Date: Apr 2006 Location: louisville
make your own or search ebay or the forsell on here
08-18-2006, 10:01 PM | #5 |
Check the for sale section here. There is 3 for sale of 50 shipped.
08-20-2006, 08:29 PM | #6 |
swamp rat could you show me pics of the chassies you would build and if i like it ill buy it
08-21-2006, 06:46 AM | #7 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
Well I built mine out of scrap aluminium. All I paid for was some threaded rod, and nuts and bolts. I used tin snips, drill press, and a hand file. |
