09-05-2006, 01:52 AM | #1 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| rockbull 2 set up
Does anyone have pics of their chassis set up. I am looking for ideas on this chassis thanx |
09-05-2006, 06:44 PM | #2 |
RCC Addict Join Date: Oct 2005 Location: $t. Helen$, OR
nope no one has ever built one |
09-05-2006, 07:09 PM | #3 |
Newbie Join Date: Aug 2006 Location: Spokane
Let's not be to much of an *** eh? hotwheels type "rockbull" in the search and it will come up with a lot of stuff. However you may get 500 threads with people saying use the search..... lol |
09-05-2006, 08:24 PM | #4 |
Rock Crawler Join Date: Apr 2006 Location: louisville
rc4wd has alot of pics of them built on there site look there
09-05-2006, 08:59 PM | #5 |
FINE!!! SEARCH BECAUSE THERE IS 1000 Threads with someones rockbull 2 build |
09-05-2006, 11:33 PM | #6 |
To all who said search I DID and saw all that was there. thanks for the usless advice Dezfan thanks for the reply I am looking mostly for link mount positions and feed back from the people that actually use that set up. I have tried a few different locations on the chasis along with changing the position from outside of the frame to the inside on the lower mounts and also eliminated the spacers they supplied in the kit and used conical washers instead.Also I am not using the bent links It seems to have helped but I was looking for a little practical advise to assist in the set up Edit: Ps I know my post count is low but that doesnt mean I dont know how to use a forum properly Last edited by hotwheels000; 09-05-2006 at 11:36 PM. |
09-05-2006, 11:39 PM | #7 |
well if u searched and found all u could find... then what are u looking for if u have seen all there is.... Just me or is this confusing? i feel a head ach coming on |
09-06-2006, 12:21 AM | #8 |
Thanks for the photos, that is generally how it was set up at the beginning before I started tweaking it. Again thanks for the help Any other experienced rockbull 2 owner out there ????????? |
09-06-2006, 04:15 AM | #9 |
Pebble Pounder Join Date: Jan 2006 Location: Chattanooga
Great to see you enjoying the truck hotwheels.Try searching for link setups and shock setups non chassis specific.Things like link angles and shock placement will generally cross over to most chassis.Dez gives great advice and has some great threads to learn from.As for the holier than thou attitude above,don't worry out of 609 posts 3 are useful.
09-06-2006, 10:55 PM | #10 |
hey CB i have had it out 2x and made changes each time added the motor mounts and 9 tooth pinions, 333oz servo, sprectrum radio,bronco body,lipo bat for comps,moved the links(lower chassis end and upper axle end) cut the rear foams,drilled holes in the rims and added wieght,eliminated the 1/8" spacers and added conical washers. It is performing real good now. How is the FG working out for you. EDIT--PS the truck has a name : Triple B ( Black,Blue,and Bloody) Goes with the color scheme and hopfully the carnage it applies to all the other peeps in the club. Last edited by hotwheels000; 09-06-2006 at 10:57 PM. |
09-06-2006, 11:03 PM | #11 | |
Whoa wait a minute!!!!! You've seen Dez's post count right, and notice when he joined the site? | |
09-06-2006, 11:10 PM | #12 |
dezfan is full of great ideas and answers if your to stupid to understand english thats your problem
09-07-2006, 02:37 AM | #13 |
Wasn't bashing Dez note other above with 6?? post count. Great so far hotwheels fouled a plug waiting on one from ddm.Cleaned er up added a futaba 2pl radio,venom failsafe,and a new 6v 4200 pack I adapted from an old welding respirator. |
