09-24-2006, 07:49 PM | #1 |
Quarry Creeper Join Date: Aug 2006 Location: olympia
| 1/4 scale servo mount
I am thinking of using the 1/4 scale servo for my build. Anyone know if these are made by TTR, thecrawlerstore, rc4wd, etc? It is my impression that these servos are cheap, durable and lots of torque? Thanks, Tim www.DrasticSports.com |
09-24-2006, 08:16 PM | #2 |
I had the same question not too long ago. I ended up making my own bracket to mount to the RC4WD axle stays I had...works great. One place I did find more available for 1/4 scale servos was guys that deal in robotics parts. Found some made of aluminum and of thick plastic...didn't fit my build though. |
09-24-2006, 08:17 PM | #3 |
Rock Crawler Join Date: Jan 2006 Location: In the basement
If you are going giant scale do it right, dont skimp on the servo. http://www.tokyo-hobbies.com/tonegawa.html |
09-24-2006, 08:22 PM | #4 |
RCC Addict Join Date: Jan 2005 Location: Green River Kentucky
I make them but they aint cheap.I hand make each set.
09-24-2006, 09:09 PM | #5 | |
09-24-2006, 09:11 PM | #6 | |
09-24-2006, 09:26 PM | #7 |
Dude, your preaching to the choir...I always build in some "overbuild" on all my 1:1 fabrication and that carries over to my RC crawler....but there is a point that you're way beyond "overbuilt". For example, on 1:1 rigs, when I build bumpers or rock sliders I use 3/16" wall, when I want to overbuild them...I may use something like 1/4" wall thickness, but the ratio your talking about overbuilding is like using something like 3/4" material to build them. The added weight and huge size is a drawback, and having 1000 oz of torque is just a "cool factor" and is way more than twice you'd ever need. If your RC crawler weighed 30-40 lbs.+ and had a wheel/tire combo that weighed 3 to 5 lbs. each...then I could see the need. |
09-24-2006, 09:30 PM | #8 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
sar‧casm /ˈsɑrkęzəm/ Pronunciation[sahr-kaz-uhm] noun 1. harsh or bitter derision or irony. 2. a sharply ironical taunt; sneering or cutting remark: a review full of sarcasms. |
09-24-2006, 09:32 PM | #9 | |
09-24-2006, 09:36 PM | #10 | |
| 1/4 scale servo
Don't yours require the wheels to be narrowed to fit? If so, can the servo be rotated 90 deg so there are no clearance issues? Quote:
09-24-2006, 09:36 PM | #11 | |
I might as well use the power steering pump off a 56 chevy... Tim www.DrasticSports.com Quote:
09-24-2006, 09:43 PM | #12 | |
Ooo, sorry, didn't sense the sarcasm...hmm maybe cause it's the internet. Ever heard of smilies . . . . . Now see, that's funny \/ Quote:
09-24-2006, 09:46 PM | #13 | |
To answer your question, the tires would probably have to have a more shallow offset(i assume thats the right term) Just narrowing the tires would keep them about the same distance, if not closer, to the servo. You have a fab shop, and I saw the rings you make. You could probably fab some up yourself pretty easily. | |
09-24-2006, 09:47 PM | #14 | |
And this is what I ended up with: Last edited by Offroader5; 09-24-2006 at 09:50 PM. | |
09-24-2006, 09:50 PM | #15 |
Just a tip when shopping for a "cheap" 1/4 scale servos............you may run into the Hitec 8805, which is a fine servo in itself, but it is BIG!!! Just be sure to match up the servo you want to use with the measurements of the mount that you may use, since 1/4 scale servos are not all built the same.
09-24-2006, 09:58 PM | #16 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Back when I ran 1/4 scales I only had to cut off the inside bead on my outbackes, I had CVD's and Syco's mounts.
