10-01-2006, 09:11 PM | #1 |
| how to get more steering, ie wheels turn sharper?
im running all stock axles. no stops removed, no CVDs, nothing how do i get the MAXIMUM amount of turning angle? what do i need to buy? knuckles? etc? any help would be appreciated... |
10-01-2006, 09:14 PM | #2 | |
Quarry Creeper Join Date: Mar 2006 Location: Eastern North Carolina
10-01-2006, 09:16 PM | #3 |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
The cheapest way is to remove the plastic stops from the hubs and shave the inner portion of the Clod stub axles. Dezfan has a how-to thread/photo somewhere on this. Just make sure your tires won't hit your lower 4-link bars with that much travel.
10-01-2006, 09:18 PM | #4 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
You also have to wory about the tie rod and drag link contacting the gearcase prior to full turn as well.
10-01-2006, 09:20 PM | #5 |
Cut the stops off the top and bottom of the knuckles, and then mod the outer axle in this manner. Nets a fairly large increase over stock. |
10-01-2006, 09:21 PM | #6 | |
10-01-2006, 09:21 PM | #7 | |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
10-01-2006, 11:12 PM | #8 | |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Thanx | |
10-01-2006, 11:26 PM | #9 | |
As for the length, it was reduces approximately 2mm. | |
10-02-2006, 08:42 AM | #10 | |
10-02-2006, 08:43 AM | #11 | |
how much is 2mm in english? (this is america ) | |
10-02-2006, 08:57 AM | #12 | |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
10-02-2006, 10:19 AM | #13 | |
The standard measurement (beleive it or not, metric measurments are used in the U.S. as well ) would be around a 1/16 of an inch. | |
10-02-2006, 03:11 PM | #14 |
thanx for the clarification Dezfan. Are you useing stock clod outdrives ???do you have any issues with the dog bones popping out after that mod id you are.
10-02-2006, 04:22 PM | #15 |
chamfering the inside edge would help then i assume?
10-02-2006, 04:39 PM | #16 | |
As long as you don't go much beyond the 2mm reduction, you should have any problems w/ the axle and stub disengaging. | |
10-02-2006, 06:06 PM | #17 |
I think having 2 esc for front/rear dig would help alot. If you did, you have to get radio with 4 or more channels
