10-03-2006, 07:10 PM | #1 |
Rock Stacker Join Date: Sep 2006 Location: U.S.
| my first attempt - 4-link
well this is what i have so far. here are the bottom links and frame: and here it is with the axles and shocks on: that is max articulation (the shocks are bottomed out). they are some old RC10T shocks i had from when i originally built the Clod (i must have 15 of those shocks laying around). it ended up being right at 17" long with almost 6" clearance. with some electronics and batteries in i set it down to a little under 5". it seems a bit too long and high to me. i'm actually thinking of cutting about 1.5" out of the middle to shorten it. the frame and links are just made from welding 1/4" and 5/16" steel rod i had laying around (since i still suck at trying to braze the brake line tubing). :-P i still need to mount the steering servos and lock the diffs, and then i'll see how it drives. since i never even drove a rock crawler (RC or otherwise), i don't have much to compare it to. if it seems okay i'll leave it like this for now. not that shortening it would be any trouble. it would probably take 1/2 hour to do it. the one thing i do need to add is some pieces of rod between the lower link mounts. i was just playing around with how to make them, and after i had it together i realized they would be like big hooks catching any rock i went over. i'm waiting to see if i want to shorten the frame before i do any other mods. i should also probaly chop off those big loops in the front and back. i had them on there because i didn't know how i was going to mount the shocks. the current setup seems okay, plus i have about 7 or 8 holes to alter the mounting locations, plus some holes to change the link locations. i'll report back after i get to run it. andy b. |
10-04-2006, 04:54 AM | #2 |
Rock Crawler Join Date: Feb 2006 Location: sunny acres
I like it. Those links are sweet; lots of adjustability. I'd throw a skidplate on the bottom too. |
10-04-2006, 06:38 AM | #3 |
Pebble Pounder Join Date: May 2006 Location: Holland
Those links look pretty sturdy! Nice ride.
10-04-2006, 09:06 AM | #4 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
I like it. I don't think you should shorten it, just lower it slightly. Let us know how the shocks perform, they look good. Cue: bunch of n00bs telling you stuff you already know, like "get different tyres" and "get some lathe motors"... Cheers 8-) |
10-04-2006, 10:08 AM | #5 | |
those babies are from about 1992. i wonder if they still even sell them. i'm going to go with the 65T lathes and a Tekin Rebel 2 ESC. i haven't decided on tires and wheels yet. i have another pair of original Clod tires and wheels that i will stick on for now. thanks all for the comments. i do have a question. what body sizes are most folks running on these? 1/10, 1/8, 1/6, etc.??? my original Clod body looks a bit small stuck on it, and the body from my 1/8 Losi Aftershock actually looks pretty good (especially if i leave the wheelbase as-is). andy b. | |
10-04-2006, 04:01 PM | #6 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Hey you need some different tires and some lathe motors Just playing, why dont you just finish it by adding a "cab" and run just the tube frame. A few more peices of tube would finish it off. I don't know if you compeat but it would be legal to run without a body that way. It may be legal now, just ugly. Last edited by Kamikaze; 10-04-2006 at 04:03 PM. |
10-04-2006, 04:19 PM | #7 |
Rock Crawler Join Date: Jan 2005 Location: Nanakuli
looks good anyways we need to know your wheel base ? then we can help with the body to run |
10-04-2006, 07:44 PM | #8 |
the WB is 17". i think i found a body that will work (and i like), the Pro-Line F-350 4-door crew cab. my kids liked it, mainly because we went to the hobby shop to look for bodies in my 1:1 F-350 crew cab. that idea of just going with a cab sounds interesting though. i do like the looks of a tube frame. i have to work on my brazing skills to try it though, as one made from all solid rod would start getting heavy. i don't compete, but it doesn't hurt to build something that follows at least some sort of rules. oh, do you guys think i need different tires and wheels? andy b. |
10-05-2006, 10:40 AM | #9 |
I think a cab, then a hoop on the back would look pretty cool. Cheers 8-) |
