10-04-2006, 03:34 PM | #1 |
Newbie Join Date: Aug 2006 Location: morrill
| stick help
i want to build a stick but i dont know what to buy to build it so if you could help thanks
10-04-2006, 03:38 PM | #2 |
Pebble Pounder Join Date: Dec 2005 Location: Parts Unknown (Eastern Sho, Maryland)
10-04-2006, 04:40 PM | #3 |
so what size of tubing do you use in making one of these
10-04-2006, 05:18 PM | #4 | |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
10-05-2006, 06:17 PM | #5 |
could you guys puit toughate a list of some sort of materales i need
10-05-2006, 06:23 PM | #6 | |
10-05-2006, 07:25 PM | #7 |
Built, not bought Join Date: Oct 2004 Location: Gresham
Here you go.It took a total of about 5 seconds to find. Project Xerox (If you can't beat them, join them!) |
10-05-2006, 11:32 PM | #8 |
Rock Stacker Join Date: Sep 2006 Location: vancouver
| stick
i use solid alum.stock 1/2 x whatever w/b you want and just drill and tap the ends and use hyme joints because its stonger than plastic also jb welding the hymes in helps to just the way i did it but search around you might find a way you like better |
10-06-2006, 09:54 PM | #9 |
RCC Addict Join Date: Apr 2006 Location: Brighton
HMMM, I might be able to hook you up with a couple a heim joint/ball ends. I have a few extras from my build...I did end up needing to sleave these with some 17/32" brass tube and then bore the clod axle mounting location to 17/32" for a tight wobble free fit. And then I drilled and tapped them, they're steel, with a 4-40 screw...just to be safe. Guess we just need to work out how to get them to Pueblo...@ $2.40 a gallon I'm not really up for a drive. Maybe you can PM me and we'll finish there if interested. Stan. |
10-07-2006, 03:46 PM | #10 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
i used 3/8 hex aluminum, ball ends for a go-cart steering, hurricane clips for the shock towers and pennies at each end for the washers to lock the rod to the ball joints.
