10-13-2006, 10:59 PM | #1 |
Rock Stacker Join Date: Sep 2006 Location: Chattanooga
| New RockBull 2 Links, Savage Shocks Added
Just added today turned out good. Before... After... Shocks and Links What do yall think?....... Overall Length is 28 inches Wheelbase is 20 inches 14 inches wide Between 6.5 and 8 inches of ground clearance. |
10-13-2006, 11:02 PM | #2 |
What class do yall think I should compete in? Super Crawler Unlimited Class |
10-13-2006, 11:10 PM | #3 |
RCC Addict Join Date: Sep 2005 Location: ...Here & There
^^^I think they are both the same thing. My thoughts... The shocks should be stood up a lil' & moved all the way to the end of the links. 89+* is alot of DAmn flex! If your competing; Do you think 20" is a good way to go? Even though your long ( ). I think you have too much weight, too high. JM.02 Other than that... I like Jack! |
10-13-2006, 11:36 PM | #4 | |
A by product of going up is going out. The COG is still in the Axles. | |
10-13-2006, 11:37 PM | #5 |
To Tall. Even for having a 20in Wheelbase. Need to lower it at least 2in. But thats just me and my style.
10-13-2006, 11:57 PM | #6 | ||
10-14-2006, 01:47 AM | #7 |
I changed back to the purple shocks. How do I go about lowering without lengthening? I will post pics very soon. |
10-14-2006, 01:54 AM | #8 |
10-14-2006, 01:57 AM | #9 |
Wheelbase is 18 inches. 7.5 inches of ground clearance. What do I need to do? What do yall suggest? |
10-14-2006, 01:57 AM | #10 |
RCC Addict Join Date: Oct 2005 Location: $t. Helen$, OR
Thought u was going to lower it I like it best in the 2nd picture... just try standing the shocks up and make shock mounting tabs taller... like raytard showed |
10-14-2006, 01:58 AM | #11 |
25.5 inches overall
10-14-2006, 01:59 AM | #12 |
In that pic the wheelbase was like 20 or 22 inches, Is that to long?
10-14-2006, 02:27 AM | #13 |
I'm about to show you the difference between preloaded and not preloaded shocks. preloaded.... 17 inch wheelbase, 7.5 inches of ground clearance. Not preloaded....20 inch wheelbase, 5.25 inches of ground clearance. |
10-14-2006, 02:45 AM | #14 |
You need to shorten the links in order to shorten the WB then go back to the 2nd picture (of this thread you showed us) setup but setup the shocks like raytard showed you This picture looks good, but it shouldnt relate to the other picture you have.... That is not proper sag, it is WAY insane you are getting 3 extra inches when you load the shocks... not a good thing... WB should stay the same you would have major problems if this was a TXT and driveshalfs were involved what happens if you stand up the purple shocks... get it to look like the above picture. but with unloaded shocks See my clod is 17" WB and 6-7" of clearence... you will find you dont need 10" of clearence if you have to right setup your tires should be ok at a 18-20" WB... though I would still go with a 17"... personally ;) Last edited by Jeepernick; 10-14-2006 at 02:48 AM. |
10-14-2006, 02:55 AM | #15 |
these rockbull bent links are long.
10-14-2006, 05:43 AM | #16 | |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
Cheers 8-) | |
10-14-2006, 10:21 AM | #17 |
RCC Addict Join Date: Apr 2006 Location: Brighton
Just a quick observation, I think the lower links need to be turned 180 degrees: put the short side towards the axles instead of towords the chassis. That looks like it'll lower your ride height, and it might limit some of that extreme articulation you've got going. I think it looked more capable before you put those links and Savage shocks on it, FWIW.
10-14-2006, 10:36 AM | #18 | |
^^^I agree! Quote:
Thanks for the correction. | |
10-14-2006, 03:22 PM | #19 |
I changed the links around and tried it a couple different ways, this is the way it seems to work the best. This is where I test and try to decide if changes help or hurt. This is the real test..... it just gets steeper and steeper...... |
10-14-2006, 03:48 PM | #20 |
That looks fun |
