10-14-2006, 10:22 PM | #1 |
Pebble Pounder Join Date: Feb 2006 Location: on the edge
| my first crawler*newer,better pics*
Well here it is for now, been working on it and driving it for a while now. just a couple more things on the way for it then it's pretty much done,,,,,well we all know they are never done. its an Inet RC v6 chassis, links, inner axle braces. RC 4wd full steering kit, clear gear covers, metal axle braces with mounting plates, adkisable motor mounts, aluminum diff lock, aluminum knuckles and wheel spacers. Traxxas big bores with 20wt oil, txt wheels narrowed over 1.25" with giant trac tires. it also has full ball bearings,and for electronics its got a Traxxas tx/rx with rear steer mod, dual Hitec 645's, Moped esc and 65t lathes with 8t pinions. so far it has been working quite well. i actually enkoy it more than all my nitro trucks. i even got a couple guys here hooked and want to build some as well. let me know what you guys think and also any suggestions on how i could improve it. front axle rear axle diff underside the poser shot Last edited by tony tt; 10-15-2006 at 09:53 AM. |
10-14-2006, 10:24 PM | #2 |
Rock Crawler Join Date: Jan 2006 Location: In the basement
Looks pretty nice, I'm enjoying the trophy used for the flex shot.
10-14-2006, 10:56 PM | #3 |
Rock Stacker Join Date: Sep 2006 Location: Chattanooga
nice
10-15-2006, 06:06 AM | #4 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
looks good. might need to move the shocks closer to the rearends, for more down force on the axles.
10-15-2006, 09:34 PM | #5 |
i tried the shocks at all different spots. any lower on the arms and the truck just sags. never tried any preload spacers yet. when these(link below) come in, i might try savage shocks mounted like in the pic above the arm. plus i don't like the lower mounts that i have now,,,the snag on everything. does anybody have a better way to mount them to the arms?? http://rc4wd.com/shop/product_info.p...oducts_id=1218 Last edited by tony tt; 10-16-2006 at 07:45 AM. Reason: forgot to add link |
10-16-2006, 09:12 AM | #6 |
RCC Addict Join Date: May 2006 Location: USA
lookin good
10-16-2006, 05:37 PM | #7 | |
Another option would be to fab up something to move the top of the shocks closer to the axles, thereby allowing you to move the bottom. | |
10-16-2006, 05:49 PM | #8 |
Rock Crawler Join Date: Jan 2005 Location: Nanakuli
looks good, but try moving the lower links to upper hole where the c brace goes gives better clearance |
10-16-2006, 06:33 PM | #9 | |
10-17-2006, 05:33 PM | #10 |
Pebble Pounder Join Date: Apr 2006 Location: Cascade, Colorado
i hope mine looks 1/2 as good when i finnish
10-20-2006, 07:39 PM | #11 |
Newbie Join Date: Oct 2006 Location: north bay
| re clod
sweet looking clod it looks sharp
10-21-2006, 09:06 AM | #12 |
thanks for the props guys. my last bit of parts came in and pics wil be up soon. i think this setup will be better.
10-21-2006, 10:01 AM | #13 |
here's some pics of the new suspension setup. i tried the black springs for a bit but they were just way too stiff. the reds seem much better and i put a medium spacer and it set the ride height just right. you can see the shock mounts are now "behind" the tires the new "c" braces i am still planning on trying savage shocks, so i made the links to fit on the second hole different body some more of my rc family l-r,,savage 25, tmaxx, savage x, and well, the clod. Last edited by tony tt; 10-21-2006 at 10:04 AM. |
10-22-2006, 04:14 PM | #14 |
Pebble Pounder Join Date: Aug 2006 Location: BINGO
Cool collection, I like the jeep body, it looks good.
10-27-2006, 05:11 PM | #15 |
hehe, those are just the truck pics. never bothered to put in the on roads and the electrics. this hobby is hard on the wallet!!
10-27-2006, 05:33 PM | #16 | |
11-02-2006, 07:50 AM | #17 |
thanks grizzly. now i figured i should just ask this here instead of starting a new thread. judging by this pic: how would i rig up bta steering? i know i should just try but to me it just doesn't look like it would work. are those carbon fibre steering links(the flat ones) really strong. i might have to go with something like that because i just don't think a tube will clear. |
11-02-2006, 08:08 AM | #18 |
Quarry Creeper Join Date: Jan 2004 Location: Long Island
Hey, this is looking good and slightly familiar. The INET chassis is great and of course Giant Tracs still rule! http://www.richardf.com/pics/inet/INET_Jeep_02.JPG Putting a battery in it sags it enough to level it off. I too had tried all kinds of shock/link/spring/mounting choices and this was the best setup. |
11-02-2006, 08:54 AM | #19 |
lol sweet ride!! i like the way you think hehe. so when you put your batt in it levels out well? what kind of battery are you using? i see your batt cradle looks small for a stick pack.
11-02-2006, 09:12 AM | #20 |
I agree, it doesn't look like a tube will clear your link-mount brackets. The best thing to do would be to swap the knuckles and see though because it is hard to tell from the pics if the bracket will get in the way of the tie rod or the steering link. I have never seen those brackets in person but maybe someone that has will help out. The carbon fiber flat tie rod should be strong enough, or you could make your own from aluminum plate. My bta steering uses a 3/16" tie rod and it just barely clears the motor. |
