10-28-2006, 11:31 PM | #1 |
RCC Addict Join Date: Mar 2006 Location: Bedias, Texas
| XRC-Super!!!
Well at first the doubters said it wasn't versatile enough. Nevermind the fact you can throw just about any trans you want into it with the exception of a 1:1. Well now we have many 2.2's out there, at least one 14 incher that I know of, a couple of nice scale bodied XRC's, a few Xtreme XRC-CF's, and now we're building our full blown super class XRC crawler prototype! I'm so excited because I have to tell you guys that this shock setup with the Revo shocks and select springs has one of/if not the best flex feel I have ever come accross. Absolutely smooth as it gets with superb dampening throughout the range of flex. As it sits it has massive clearance and will be able to run a super slammed body. We are going to have to install wideners on it and tweak everything out but at this point it couldn't look better. Thanks, David Xtreme Rc Hobbies Last edited by insanerc; 10-29-2006 at 12:59 AM. |
10-28-2006, 11:36 PM | #2 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Looks okay, but the shocks are at such a retarded angle I don't see how it would function well on the rocks. Stand them up, there's enough leverage from the links to get good clearance. |
10-28-2006, 11:56 PM | #3 | |
David Xtreme Rc Hobbies | |
10-28-2006, 11:57 PM | #4 |
Revo shocks are so stiff and slow, I bet they work pretty good right there.
10-29-2006, 12:08 AM | #5 | |
David | |
10-29-2006, 12:11 AM | #6 | |
Sorry, didn't mean to offend, I know my wording was less than ideal. But seriously, at least try standing the shocks up (not all the way, but at least enough for them to actualy have some damping force on the axles) and get your upper links parallel to the ground. Clearance and travel is nothing if you have a floopy rig with horrible suspension geometry. Just a sudgestion based my 5+ years of rock crawling experience. Last edited by Highmark; 10-29-2006 at 12:14 AM. | |
10-29-2006, 12:20 AM | #7 | |
David | |
10-29-2006, 06:48 AM | #8 |
im gonna keep an eye on this ....
10-29-2006, 11:33 AM | #9 |
Okay, I've now lowerd the top links very near level, and have moved the Revo shocks closer to vertical. Right now the bench test tells me I need to go back to a softer spring perhaps. David |
10-29-2006, 12:22 PM | #10 |
Newbie Join Date: Jul 2005 Location: australia
the only thing that lowering your front links to parrallel with the ground done was make your AS go way up in the front wich will cause it to unload alot easier
10-29-2006, 02:03 PM | #11 |
Those XL's make your chassis look tiny.
10-29-2006, 02:10 PM | #12 | |
Well, if you don't need it then why have it? David | |
10-29-2006, 02:32 PM | #13 |
Pebble Pounder Join Date: Oct 2006 Location: belgium, roeselare
looks great |
10-29-2006, 06:54 PM | #14 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Nice lower shock mounts. :-P What's the wheelbase, it looks short. |
10-29-2006, 07:09 PM | #15 | |
That looks freakin A. Good work. | |
10-29-2006, 07:30 PM | #16 | |
David | |
10-29-2006, 07:32 PM | #17 | |
David Last edited by insanerc; 10-29-2006 at 07:42 PM. | |
10-29-2006, 07:42 PM | #18 |
I would be worried w/ the shock mounts mounted in the middle like that they would break easy?
10-29-2006, 08:56 PM | #19 | |
Thank man, glad you like the changes. I took you're advice, I'll have to see how it works on the rocks. David | |
10-29-2006, 09:00 PM | #20 | |
