11-07-2006, 08:11 AM | #1 |
Rock Crawler Join Date: May 2006 Location: Burrillville, RI
| stock pinions with a 65t and a 75t lathe
I am in the process of building a torsion clod with Giant Tracs... I was wondering if using a 65t and 75t lathe motor with the stock pinions would work(yes I did try to search) I figure the speed should be ok and because they are lower speed motors... that they would have no issue with torque.. Any help is appreciated! |
11-07-2006, 08:13 AM | #2 |
Rock Crawler Join Date: Feb 2004 Location: Michigan
I have seen 65t with stock pinions work great on a 2.2 rig but doubt it would have the torque for your project. just my opinion
11-07-2006, 08:15 AM | #3 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
I have used stock pinions with 65 turn lathes on a 2.2 clod... had tons of wheel speed (for a crawler) and crawled slow speed pretty well. Had the tires been taller or heavier (like your giant tracs) I dont think it would have crawled well at all.
11-07-2006, 08:30 AM | #4 |
ok... looks like I will have to suck it up and get some motor mounts...
11-07-2006, 08:16 PM | #5 |
Newbie Join Date: Oct 2006 Location: Essex
or you could just mod your tranny case like i did, no problems so far.
11-08-2006, 12:18 AM | #6 |
Rock Stacker Join Date: Sep 2004 Location: Spanaway,WA
I have 55ts in my clod and stock pinions and I don't think I will ever change it. I like to have a little more wheel speed in case I need it and it will crawl pretty slow with a carefull touch on the throttle. Using cut clod tires for now.
11-08-2006, 12:46 AM | #7 |
Newbie Join Date: Dec 2005 Location: Everett, wa
I have 65t's currently on my clod with nylint tires, and they are a totally weak motor, I had 55t's before and will be putting them back in(almost did it tonight but got lazy) and buying motor mount's and pinion's, the 55's are good for now but it will be underpowered when I get my moab's.
11-08-2006, 01:17 AM | #8 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
im running 55t motors and stock pinions with moabs and love the performance i get from it! i can feather the throttle when i need to go slow and still have alot of wheel speed when i need it! I think 9t pinions are great most of the time but there are times when wheel speed is needed and i just learned how to drive instead of depending on gears to do it for me! |
11-08-2006, 10:27 AM | #9 |
Pinchflat and Kaetwo used to run Giant Tracs, 55T motors, and stock pinions. Their rigs worked great. I've never used the 65T motors I have but I imagine they would work good too in that setup.
11-08-2006, 10:33 AM | #10 |
I wanna be Dave Join Date: Jan 2004
I'm doing 45 Turn Axiom motors with 8 tooth pinions and running 6 inch tall Proline Badlands tires.
11-08-2006, 10:38 AM | #11 |
I guess Ill try it then.... I can always go to a smaller pinion...
11-08-2006, 11:35 AM | #12 | |
11-08-2006, 12:06 PM | #13 |
RCC Addict Join Date: May 2006 Location: USA
scott your be fine i ran (2) 65 turns on my gecko 2 pro right when i got it with stock pinions and had noproblems. i went to 8 tooth pinions only because i already ordered them.
