Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: Bad day for my pimp cane rig
Old 01-23-2007, 06:54 PM   #1
Default Bad day for my pimp cane rig
Well today i finally got my pimp cane build setup where it worked like i wanted.
So i figured it was time to see what it was really capable of.I have for some reason adopted a hammer down driveing style with this rig and it came back to bite me.
The pimp cane chassis was overcoming obsticles that my CFNN would not think about. After about 10 minutes one rear wheel stoped spinning but i was not ready to stop beating this thing and the next thing i new one of the esc's cought fire.
After taking the rear axle apart i found that i striped one side of the TTR diff lock wher the brass hex goes and for the moped esc i could not tell you what went wrong.I did notice before it cought fire the front would stop for a split second and then pull again.
After i get my new parts in Is there a way to keep the hex from stripping the new locker again? And i guess it is time to buy a better set of esc's.
I am thinking of going with the mamba max esc's does anyone know what the bec rating is and what voltage they send to the servos?
joesbruiser is offline   Reply With Quote
Old 01-23-2007, 07:02 PM   #2
I glue my hexes in, it helps alot.
Kamikaze is offline   Reply With Quote
Old 01-24-2007, 12:17 AM   #3
I joined the Band!
3 Amps.
KING BLING is offline   Reply With Quote
Old 01-24-2007, 06:27 AM   #4
Yeah fire ,and it sucked to have to grab and unhook a deans plug in the middle of it.
Old 01-24-2007, 08:47 AM   #5
pics of the carnage would be cool...
K_Willis is offline   Reply With Quote
Old 01-24-2007, 08:59 AM   #6
Don't use derlin hexed lockers. We offer aluminum versions that won't strip out under a heavy load. RC4WD and others do as well.
CPE MT is offline   Reply With Quote
Old 01-24-2007, 09:22 AM   #7
Mamba max esc's bec rating is 5V 3A.
RockDragon is offline   Reply With Quote
Old 01-24-2007, 11:37 AM   #8
Powered by Awesome
TwistedXT's Avatar
ive got a locker that uses metal where the hexes join the axle shafts... i think thecrawler store is carring them now.... like 30 bucks.
TwistedXT is offline   Reply With Quote
Old 01-24-2007, 12:29 PM   #9
I hear ya on the whole "MOPEDs catching fire" thing, they sure don't like water... I was bombing my Mad Bull around in short, wet grass, and even the spray from that was enough to produce flames. Now the whole buggy stinks of magic smoke... :-(
4link4eva is offline   Reply With Quote
Old 01-24-2007, 01:00 PM   #10
No pics? Did you burn your hands while trying to unhook your batts?
minijosh is offline   Reply With Quote
Old 01-24-2007, 01:24 PM   #11
We want to see some pics of the carnage....:-P
sportsman1213 is offline   Reply With Quote
Old 01-24-2007, 02:07 PM   #12
I was not thinking or i would have got some pics of the esc but today was trash day so i threw the pos in the trash lastnight.I can get some pics of the locker i saved it so i could salvage the gear.
It was rather cold yesterday and i had on gloves so no burns .
Old 01-24-2007, 02:11 PM   #13
CPE MT pm sent
