Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Clod Buster
Thread: Lockers
Old 05-24-2004, 10:21 PM   #1
Default Lockers
Hey has anyone used hot glue to lock diffs. If so how good is it?
ExtremeOffRoad is offline   Reply With Quote
Old 05-25-2004, 01:14 AM   #2
PapaGriz Yo
Grizzly4x4's Avatar
Default Re: Lockers
I've never done it but I have heard people recommend it. Supposedly you can peel it off the gears if you ever want to unlock it.
Grizzly4x4 is offline   Reply With Quote
Old 05-25-2004, 07:05 AM   #3
Default Re: Lockers
yes, i use hot glue to lock the diffs. it works great.
crippler is offline   Reply With Quote
Old 10-16-2004, 04:16 PM   #4
Default Re: Lockers
where do you apply it to
spicollie is offline   Reply With Quote
Old 10-16-2004, 08:19 PM   #5
Default Re: Lockers
Onto the spider gears.
Click for a tutorial.
He used epoxy, but it's the same process for any other adhesive.
Clod_Master is offline   Reply With Quote
Old 10-16-2004, 09:23 PM   #6
Default Re: Lockers
thanks thats helpfull. but what about the traclock gear at rc4wd will that work the same as JB weld
Old 10-16-2004, 09:25 PM   #7
Default Re: Lockers
i got two trak gears in my clod and dont buy them its a waste of $60 just jb weld them uless you like spending money when you dont have to
bigred is offline   Reply With Quote
Old 10-17-2004, 12:14 AM   #8
31st place in 2006 Nats!!
toyofast's Avatar
Default Re: Lockers
We, RCRockGear sell the MTPA/Centipede Engineering's Diff Discs for the Clod. Simple bolt on deal.
Clod Diff Disc's - $45.00 (sold in pairs) IN STOCK
toyofast is offline   Reply With Quote
Old 10-17-2004, 08:48 AM   #9
Default Re: Lockers
thanks i think i'll go with the discs. but i cant pull them up under crawler essientials. could you give me direct link
Old 10-17-2004, 01:49 PM   #10
Default Re: Lockers
The Trac gear and Diff disks aren't a waste of money. The advantage that they give you is a metal hex. I've stripped the hex out of the stock plastic gears a couple of times with a diff locked in the normal fashion.
