09-23-2017, 11:20 AM | #1 |
Newbie Join Date: Jun 2017 Location: Brandenburg
| Links length
First I'm new to the RC crawler world. I'm wanting to build one with clod Axel's. I have chassis plates from a redcat Everest I was wondering if anyone could tell me how long my links need to be. Or point me in the right direction with them thanks .
09-23-2017, 01:29 PM | #2 |
| Re: Links length |
09-23-2017, 09:31 PM | #3 |
| Re: Links length
The everest chassie sucks no suspention adjustments and the geomitry realy sucks for a crawler i cut my e10 chassie out of a plastic cutting board material and it is working great and very easy to work with u can use the e10 chassie as a basic templet for size and upper mount locations maybe make the chassie a bit longer to make sure there is enuff material to drill alot of holes to adjust.the.suspention You can make th3 links any size you want i would sugjest you start with the lower links first just make 4 the same size then do the upper links Last edited by ferp420; 09-23-2017 at 09:35 PM. |
09-24-2017, 07:15 AM | #4 |
| Re: Links length
Thanks
09-24-2017, 08:30 AM | #5 |
| Re: Links length
I sometimes use bic pens for mock up links but there only so long but the rod ends fit inside perfictly and a drop of super glue holds them in place untill your ready to make real ones
09-24-2017, 02:29 PM | #6 |
| Re: Links length
Think I will try that
Links length - Similar Threads | ||||
Length for wraith lower links and twin hammer links | Rckhrse | General Scale Talk | 0 | 08-22-2013 03:53 PM |
What length links for your BJ | Trimmy | Axial AX-10 Scorpion | 2 | 03-10-2008 11:33 PM |
What length should my links be | bvitale | General Crawlers | 3 | 06-27-2007 10:16 AM |
length of links | kacz7895 | General Crawlers | 3 | 06-08-2007 05:45 AM |
Links- length and how many is necessary ?s | Tig | General Crawlers | 4 | 05-26-2007 12:15 PM |
