02-08-2007, 09:43 AM | #1 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
| StÝcklÉr
Well the other post was moved so many times it made my head spin. So I deleted and thought I would do this the correct way. The design is based off the Stick® ideals. I gues you can call it a suspension set up more than anything else. Kinda like a 3 link. I had to put this on hold for quite some time until I found out what the comp rules stated for width, hight and length. Clodstall will be adding the Tech soon after. Here is the teaser shot you saw yesterday. I'll add the real pics after Clodstall posts the tech. I posted this only after I had approval it would be ok with Kevinlongisland (the Crawler store) to use Stick® references. All thought Styckler in no way represents Kevin or the Stick® Chassis. I had the idea after looking at a Stick®, so I wanted to give proper thanks to Kevin and the Crawler store for allowing me to refer to the Stick®. Last edited by Double J; 02-08-2007 at 09:50 AM. |
02-08-2007, 09:50 AM | #2 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
the specs will be: Moabs xl's probably 55 turns 8 tooths CB-995 steering servo Moped 16R esc more later. Last edited by clodstall; 02-08-2007 at 10:28 AM. |
02-08-2007, 10:04 AM | #3 |
oh yeah clod axles bearings on the way for it body panels? |
02-08-2007, 10:15 AM | #4 |
Pics. I tried to keep the pics to a minium and also because I've changed the design about 5 times. I have 4 half finished tubers started. It's lower half is 1/4" tubing and the top is 3/16" to try and lighten it up a bit. I'll also be adding a little something special to it. So stay tuned. At this point it's about 75-80% done. Last edited by Double J; 02-21-2007 at 09:13 AM. |
02-08-2007, 10:34 AM | #5 |
RCC Addict Join Date: May 2006 Location: Roseville
Well this has certainly peaked my interest. Are those heim joints on the front/back? Looks like it might be top-heavy, or are my eyes playing tricks?
02-08-2007, 01:57 PM | #6 | |
It may be a little top heavy but I'm going to see how it sits on shocks before I make the call. If I do lower it, it will be about 1/2" and why I haven't put the side braces on it yet. | |
02-08-2007, 03:23 PM | #7 |
it will be ok im going to run hub packs if possible. |
02-08-2007, 03:32 PM | #8 | |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
02-08-2007, 03:40 PM | #9 | |
It will have a mounting point on the backbone for a 2 shock version or he can choose to put 4 shocks on it attached to the tube frame. This way it won't have to be sent back for a better set up. | |
02-08-2007, 03:50 PM | #10 |
RCC Addict Join Date: Apr 2006 Location: Brighton
Intresting...I think that tube cage will be a hinderance, but neat to see an outside the box idea. I don't see how 4 shocks would work...they'll act as lock-outs...no articulation. Unless I'm missing something |
02-08-2007, 03:59 PM | #11 |
i ran 4 shocks on my other one and it did good. not like now with 2 though. oh yeah Jason your pm box is full. |
02-08-2007, 04:36 PM | #12 |
Not anymore. deleted some space for ya. I'll have the 4 shock set up at a pretty decent angle and it will give less articulation. We'll see how it works out. jj |
02-08-2007, 05:30 PM | #13 |
Rock Crawler Join Date: Jul 2004 Location: Mt.View CA
Could you use square aluminum instead of the steel?, looks like it could be a bit heavy.
02-08-2007, 05:53 PM | #14 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
A local guy did that about a year and a half ago and entered the "World Crawler buildoff" or whatever it was. I seem to remember it doing decent in competition. |
02-10-2007, 02:02 PM | #15 |
esc and servos on the way. motors soon to follow.
02-10-2007, 06:20 PM | #16 |
I'm wondering if a "grid" or "screen" could be used as side, hood and roof panels? If so How tight does it have to be? Any rule makers have any in put for me? |
02-10-2007, 08:39 PM | #17 | ||
02-12-2007, 08:33 PM | #18 | |
I could of just searched for the rules. Thanks jason | |
02-12-2007, 08:57 PM | #19 | |
Quarry Creeper Join Date: Feb 2006 Location: Shillington
02-15-2007, 05:19 PM | #20 |
got the esc the other day still waiting on motors and servos now. will order pinions later.
