02-09-2007, 11:52 PM | #1 |
Newbie Join Date: Jan 2007 Location: Gig Harbor
| New member, new crawler
Here's my first crawler....gotta say, it's a blast to drive! Built around Clod axles. Quick spec list: Front and rear RC4wd Store steering linkage >Heavy duty kimbrough servo savers >Crawford performance diff lockers front and rear >Carbon fiber 4 link setup >RC4wd 4 link mounts >Hot bodies shocks >Hitec 645mg servos >6 cell 3300 pack, lasts about an hour >RC4wd 8 tooth pinion gears >Integy 75T motors >shaved stops for better turning >articulates too much (90 degree easy) >cut and BB filled tires on narrowed clod rims (will change soon) >Airtronics 6 channel radio. F/R axles can be steered independantly of each other. Steering is a bit lacking tho, not turning lock to lock unless I'm moving. Might try not running the rear servo for now. >cut Bronco body |
02-10-2007, 05:56 AM | #2 |
Nice rig man , i would however get rid of the servo savers if you are having trouble with steering travel.
