03-04-2007, 02:06 PM | #1 |
Pebble Pounder Join Date: Nov 2006 Location: Fernley,NV
| aluminum axle skids!!
well after trying to make skid plates for my aluminum axles and not liking how any of them turned out i started thinking about some type of epoxy that would set up hard like plastic and bond good to aluminum.so this is what i found,its a 2 part self leveling(comes out like liquid)concrete joint and crack filler,supost to bond to any clean surface. i put some on a peice of card board and let it start to set up(about 30 to 60 seconds)then kinda troweled it on with a peice of plastic.after about 2 minutes you cant work with it any more,after 24 hours its hard,you can sand or grind it and it slides over the rocks and dont hang up.only down side is its a little over $50 bucks for the kit and a duel caulking gun.up side is you save your aluminum axles,it'll work on plastic axles,and you could probable do 300 sets of axles with 1 kit !! Last edited by throttleboy; 03-04-2007 at 02:10 PM. |
03-04-2007, 02:23 PM | #2 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
if your that worried about scratching your axles just stick with plastic. i wouldnt put that on alu axles. |
03-04-2007, 02:26 PM | #3 | |
Newbie Join Date: Aug 2006 Location: vancouver
he so right . man alu axles and your worried of scratches.but thats your thing so kool . | |
03-04-2007, 02:35 PM | #4 | |
03-04-2007, 02:43 PM | #5 |
So run aluminum outer tubes and plastic gear cases |
03-04-2007, 02:51 PM | #6 | |
03-04-2007, 02:53 PM | #7 | |
03-04-2007, 07:27 PM | #8 |
Pebble Pounder Join Date: Oct 2006 Location: Enterprise
That stuff actually looks like plastic on there. Pretty neat.
03-05-2007, 03:55 PM | #9 |
Rock Crawler Join Date: Feb 2006 Location: Easthampton
if you need to get into the axles again, how easily is that stuff gonna come off so you can split the halves?
03-05-2007, 04:34 PM | #10 |
Pebble Pounder Join Date: Nov 2006 Location: northampton
You could have easliy made a small skidplate out of alum sheet or steel. i wouldn't have spent tons on alum axles and goop them up. But that's just me. i'll post photos soon of my progress on my new project. just waiting on a body
03-05-2007, 08:30 PM | #11 |
Pebble Pounder Join Date: Sep 2005 Location: Columbus
Afraid to scratch your rock crawler......what is that all about....?
03-05-2007, 10:01 PM | #12 |
Quarry Creeper Join Date: Jan 2007 Location: Alberta, Canada
I think he didn't care about scratches but didn't want holes.
03-06-2007, 01:48 AM | #13 |
Rock Crawler Join Date: Apr 2006 Location: louisville
its alum if no ones wore through the plastic ones i wouldnt worry about alum
03-06-2007, 06:07 AM | #14 | |
03-06-2007, 06:09 AM | #15 | |
03-06-2007, 07:02 AM | #16 | |
03-06-2007, 09:08 AM | #17 |
Did you ever sand that down and smooth it it? Looks fugly.... |
03-06-2007, 09:30 AM | #18 | |
03-06-2007, 09:41 AM | #19 | |
03-06-2007, 09:47 AM | #20 |
Well get to it ot let the rocks do it.... |
