Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: Narrowed Clod wheels and backspace?
Old 03-09-2007, 06:12 AM   #1
Default Narrowed Clod wheels and backspace?
I have checked all of the threads for how to narrow a clod wheel but I still need to know if it is better to narrow the inside bead or the outside bead. I am building two crawlers at once so new rims and tires are not in the budget yet.:-(
STJ7780 is offline   Reply With Quote
Old 03-09-2007, 06:27 AM   #2
Do you have clearance issues when turning? ARe you wanting your track width wider or narrower? Way are you narrowing them in the first place?
Old 03-09-2007, 12:05 PM   #3
I don't have any clearance issues. I am narrowing them to get better sidewall bite. I just wanted to know what the most popular method is; narrow from the inside, making the track wider, or outside, making the track narrower. I am using the stock clod wheels and tires because I don't have enough money for new wheels and tires.
Old 03-09-2007, 01:13 PM   #4
I narrowed mine on both sides of the rim... I did it to gain more inside cleareance so the tires wouldn't hit the link bars and to help with sidewall grip.
I just cut the bead part off and flipped it around and slid it back over the center of the rim. seems to work farily well for me...
rcktpwrd is offline   Reply With Quote
Old 03-09-2007, 02:04 PM   #5
I narrowed mine on the inside bead.
4link4eva is offline   Reply With Quote
Old 03-10-2007, 05:19 AM   #6
Thanks for the help guys. I ended up narrowing the inside bead and so far it worked great. Now I need to finish the chassis and links so that I can see how everything will perform overall.
