04-05-2007, 08:09 AM | #1 |
Newbie Join Date: Mar 2007 Location: Middle Of No Where
| Front Axle Clod Stall?
I recently built a CFNN clod 16 inch wheelbase. Im using integy 55t motors and 8tooth pinions but last night when i was crawling around i would drive up to an obstacle and the front tires would start to climb the obstacle then it would stall out; and the rear axle would keep turning. I thought it was suppose to happen the other way. im using a tekin rebel 2 with hitec 645mgs and a 6 cell 1700mah battery. any help? Casey |
04-05-2007, 08:21 AM | #2 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
Whatever axle has the most load will stall.
04-05-2007, 08:58 AM | #3 |
So Do Think I Have A Problem Or Its Just Normal?
04-05-2007, 08:17 PM | #4 |
im thinking its not normal. i just tried it again after i checked my wiring over and once it stalls out i can pick the crawler up and the front axle still wont turn until i move the tires a little by hand to sort of jump start the motor. do you think its the motor? what could this be??
04-05-2007, 08:29 PM | #5 |
Pebble Pounder Join Date: Feb 2007 Location: Monrovia
most likely is the motor. try changing it out, if that doesnt fix it, it is always nice to have a spare motor. but, i would say its the motor.
04-05-2007, 09:20 PM | #6 |
Quarry Creeper Join Date: Oct 2006 Location: kansas city
Try checking the brushes on the front motor. It sounds like a hung brush to me. Later,Randy |
04-05-2007, 10:38 PM | #7 |
Newbie Join Date: Feb 2007 Location: cocoa
sounds like the motor!!!!!
04-06-2007, 05:49 AM | #8 |
how do you check the brush on the motor? Im new to electrics youll have to excuse me
04-06-2007, 06:26 AM | #9 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
how is the truck wired? Series or parallel ?
04-06-2007, 08:28 AM | #10 |
Its wired in parallel. I followed some of the pictures I found on here i forget the website but that doesnt matter. Its wired in parallel
10-11-2008, 01:24 AM | #11 |
Pebble Pounder Join Date: Apr 2006 Location: Anchorage
Also how are the front axle gears/bearing? Mike |
10-11-2008, 01:39 PM | #12 |
RCC Addict Join Date: Feb 2008 Location: tauranga north island new zealand
Mine did the same thing,front stall? so i pulled out the brushes and refitted them again,all good now,they must need reseating or something (proberly a tech term for it ).
10-11-2008, 02:42 PM | #13 |
Newbie Join Date: Sep 2008 Location: san luis obispo
How did you lock your diffs?( are they locked) I did mine with epoxy and a little drip got onto one of the gears and it would stall on the drip every once and a while, cleaned all my gears and ran much smoother.
