Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: Super Pimp finally done!!
Old 04-18-2007, 11:18 PM   #1
Default Super Pimp finally done!!
Well I don't have any action pics yet because it only has one battery in the dark tonight to test. Let me say that I'm very pleased with the pimp cane and am glad I could use the info from everyone on this forum to use all the right stuff.
Here's a quick rundown:
17" reverse rear pimp cane
XTM Thorns narrowed to 2" w/moab XL's
RC4WD 3/4 12mm to 14mm adapter
Thundertech BTA front and rear
Hyperion 3013's that I turned down w/ 8 tooth pinions
Dual Mamba 25's
JR DS8711 in front
Hitec HS-5955 in rear
Hitec 8 channel 75MHZ reciever....yes 75MHZ
Controlled by a Hitec Eclipse 7 obviously on 75MHZ! It's nice to be able to mix both speed controls on one stick and be able to disable the mix at the flip of a switch, I could learn to like this setup.
I think that's all the important stuff
I will say that with dual digital servos and dual brushless motors this is one noisy beast but Ohhh how the torque is nice...
totalxbadass is offline   Reply With Quote
Old 04-19-2007, 05:08 AM   #2
Looks pretty good. Get you some knuckle packs and it will be even better. How are you liking those motors? They look sick in there.
Old 04-19-2007, 06:13 AM   #3
That looks really sick. Good job!
What's the rig in the background?
muddeprived is offline   Reply With Quote
Old 04-19-2007, 06:42 AM   #4
Looks good, Give me them motors!
Brandon M is offline   Reply With Quote
Old 04-19-2007, 08:22 AM   #5
yeah, I'll be building knuckle packs when time permits.Also....I love the motors, very imppressive. That in the background is a savage crawler, my first build also.
Old 04-19-2007, 04:37 PM   #6
Holmes Hobbies
CD13's Avatar
looks good,I just did the same thing except mamba maxs and spec. 6 radio.do you like channel mixing?
CD13 is offline   Reply With Quote
Old 04-19-2007, 06:18 PM   #7
That looks awesome, good work.
The knuckle packs will make a night and day difference on that truck.
Highmark is offline   Reply With Quote
Old 04-19-2007, 07:29 PM   #8
You know I really am starting to like the mixing...I've only had one day on it but it makes life so much easier. Even with the brushless one motor or the other may have a slight tendancy to slow more that the other and to be able to add a little throttle on the other stick to get the rear pushing or keep it by pulling the stick back makes certain obstacles so much easier.
I don't want these motors to be destroyed by my bashing nature so I rigged up some really rough motor guards until I get a better Idea, so far they work pretty well. They go around the steering also so that's kind of nice, I didn't have much of a choice though.
Old 04-26-2007, 11:12 PM   #9
Well I got the knuckel packs done and really like the way this thing handles with them. With the narrowed thorns and the wideners, battery swaps will be real easy also. I'm going to try to get a couple short videos on here tomorrow evening to show that this thing actually does move.
Old 04-26-2007, 11:52 PM   #10
Looks good...I need to hurry and get my Super done... Lets see that Video when you get it ready...
Old 04-28-2007, 01:40 AM   #11
You have found really nice spot for your cells.
klrp is offline   Reply With Quote
Old 04-29-2007, 12:14 AM   #12
Got the new camera up and running so I figured I'd test it out this evening. Here's a little video of the pimp in action.
http://vids.myspace.com/index.cfm?fu...oid=2025769754
Old 04-29-2007, 09:15 AM   #13
raul duke's Avatar
Love the soundtrack on that vid. Start down count. The rig performed well yesterday and evan kept up with the pimpslap. That channel mixin sure does make a diff I might have to consider some change after seein some of that action up close.(probly not I think I can still take ya) You'll have to let me drive it next time. Good work all around.
raul duke is offline   Reply With Quote
Old 04-29-2007, 09:23 AM   #14
Thats a sweet ride man, I love that dual BL setup.
Benny is offline   Reply With Quote
Old 04-29-2007, 02:22 PM   #15
thats one bad a$$ rig you have going on. just wanted to know how you tuned down motors
newbie8324 is offline   Reply With Quote
Old 04-29-2007, 11:37 PM   #16
I'm guessing you're asking how I turned down the motor shafts?? I just took the motors apart and put the shafts in a lathe and turned them down.
Oh yeah.....and today I snapped a damn axle shaft so I guess it's time to get some CVD's.
