04-29-2007, 08:50 PM | #1 |
Quarry Creeper Join Date: Aug 2006 Location: olympia
| Stick with 4 link chassis to clod axle issue
There is a single bolt at the top of the clodbuster axle that connects to to stick/4 link type chassis. I just snapped it and now have to tap it out. Is there a better way to hold the chassis to the clodbuster axles? Thanks, Tim DrasticSports.com |
04-29-2007, 08:52 PM | #2 |
Pebble Pounder Join Date: May 2006 Location: fremont
better bolts, gets some SAE 9 grade bolt., or some m5 grades to think of it.
04-29-2007, 09:10 PM | #3 |
You snapped the bolt off inside the backbone? Or did you snap off the bolt that runs vertical through the gearcase? If the backbone bolt, then yes...use some grade 8 hardware and you should never have to worry about it. If that's what it is already...then try some F911 grade 9's If in the gearcase...isn't that a composite rod end? Just buy more of the rod ends...they are only $9 from Crawlerstore. |
04-30-2007, 11:40 AM | #4 |
post a pic of whats broke. its much easier.
