05-19-2007, 03:32 PM | #1 |
Quarry Creeper Join Date: May 2007 Location: NCVRCC
| Narrowing Clod axles???
Is it possible to narrow clod axles :-( ? If so how is the best way to do so. Thanks. |
05-19-2007, 03:52 PM | #2 |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
I haven't seen a set of narrowed Clod axles, and to do it is going to require a fair bit of custom machine work (new axles, axle tubes, hubs, etc.) The easiest solution, other than a different set of axles, is to look for some low offset wheels to narrow up the truck. |
05-19-2007, 04:14 PM | #3 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
yes it is possible.. I have been working on a set right now, but I have a handful of projects on my plate and none of them seem to be getting done Cut the axle shafts in half and take out the desired width. When putting them back together, put the end of your shaft as a D shape(half of it) and do the same to the other half. That way they fit together and have better strength than just cutting them in half and slapping them back together. The flat portion on the shafts will add to the strength. Same goes for the axle tubes.. You can also make a sleeve or tubing of some type to add more strength to the cut areas. Then you just need to cut down the axle braces and slap them back together... Just take your sweet time doing it |
05-19-2007, 04:30 PM | #4 |
05-19-2007, 05:14 PM | #5 |
better pics on the last page Last edited by TwistedCreations; 05-19-2007 at 05:17 PM. |
05-19-2007, 05:17 PM | #6 |
| Nope. That pic was photoshop'd. I have files and starting production on somehting like this. I just made that pic for looks. And those wheels are Non-Offset and without CVD's. I now have Mod'ed CVD, RD400 Beadlocks and a few other little things to help with width. But I do plan on making CVD's and Axle Tubes This year for sure.
05-19-2007, 05:19 PM | #7 |
cool cool |
05-19-2007, 09:06 PM | #8 |
AKA 2G's Join Date: Feb 2006 Location: Where the wind blow's
Try this works great for me, did it with a drill and dremel tool. Im at 12 1/4 with clod beadlocks, cvds and badlands. I could go even more narrow if i wanted to go back to ped wheels.
05-23-2007, 10:01 PM | #9 |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
86jeep: What hexes are those?
05-23-2007, 10:17 PM | #10 |
Newbie Join Date: Oct 2006 Location: northern
Looks like a lot of work
05-23-2007, 10:49 PM | #11 |
it's not alot of work at all...I have a write up on my website that Mnster did on doing that mod. Those Hex's look to be the same ones Mnster and I both did. Which would be LST2 14mm Adaptors.
05-24-2007, 06:08 AM | #12 |
THAY ARE THE SAME ONES THAT CAME WITH THE CVDS FROM THUNDERTECH 12MM JUST MOVED THE HOLE AND CUT OFF THE OLD PART. ITS NOT THAT MUCH WORK IT TOOK ME ABOUT 30 MIN TO NARROW THE HUB DRILL IT OUT,CUT THE AXLE DRILL NEW HOLE AND CUT THE HEX DRILL NEW HOLE. SO 1 HOUR TO DO THE FRONT run2jeepn I SAW THE WRITE ABOUT THE 14MM HEX BUT WHERE IS THE ONE ABOUT THE NARROWED HUBS THANKS |
05-25-2007, 01:53 PM | #13 | |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
i am assuming you are planning at aiming these towards the 2.2 crowd, so i would suggest that you make a STRAIGHT axle tube for the rear axle! | |
05-25-2007, 02:39 PM | #14 |
05-28-2007, 08:47 AM | #15 |
