06-03-2007, 09:29 PM | #61 |
RCC Addict Join Date: Mar 2007 Location: des moines
no I love the power of the 3013's Im wasnt happy with the power of the axiom 65t motors but there back in the truck I didnt liek the duel brushless at all Im going to try again when I get my aother 3013 and 4mm plug so I can use the mamba max's
06-04-2007, 06:40 PM | #62 |
well after some more testing Im very happy with the axiom 65t motors.I ordered jd knunkles and 6t pinions today I hope to have them and the new servo mounts in time for the comp this weekend
06-06-2007, 03:29 PM | #63 |
I take the rig out for some testing today.the truck did great.alittle more flex then I like but non the less im very happy with it.I only stripped a 5955 servo and broke an axle tube so it was a good day.I also got my jp knuckles and 6t pinions.the motor did stall out perrty easy with the 8t/9t gearing I was running but I think the 6t pinions will help with that.I need to mod the axle cases to get the pinion to fit right.they are only half way engaged
06-07-2007, 04:42 PM | #64 |
I got the gear to mash better.other then needing to test alittle more I perrty sure the rig is ready for the comp.I feeling pertty good about the comp I would like a top 3 |
06-07-2007, 05:16 PM | #65 |
I got the gears to mash better.rig is ready for this weekends comp Im hoping for a top 5 Im going to try and get alittle more time testing but Im feeling perrty good about the comp
06-07-2007, 06:02 PM | #66 |
Decided to keep the feel of the brushed motors in there for the comp?
06-07-2007, 06:18 PM | #67 |
yeah.duel brushless is still to new to me to setup and tune in days.after this comp I want to go brushless
06-07-2007, 10:07 PM | #68 |
It is always best to drive what you are familiar with during a comp. Once you get some time to play around, I suggest gearing as slow as possible and using more voltage to get your wheelspeed back.
06-08-2007, 06:40 AM | #69 |
after this comp when I go brujshless what mootrs do you think I should use.think the axles would be up for 2 3025's |
06-08-2007, 07:18 AM | #70 |
Nope, you will spend more time wrenching on them than driving. A guy here just put 3025's in his clod, I was talking on the phone with him for like 5 minutes when he fired it up, in that time he shredded all the gears in the axles and ripped the motor clean off the axle. |
06-08-2007, 07:29 AM | #71 |
hmm that dont sound good |
06-08-2007, 01:49 PM | #72 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Integy just came out with a metal gear set. Might want to get that if you are doing brushless. http://integy.automated-shops.com/cg...06107623277.81 |
06-08-2007, 11:16 PM | #73 |
hey thanks for the link.I need to get some gears.anyways I will be running with rig at the comp somethings has come up with the hustler :-(
06-09-2007, 03:23 AM | #74 |
I got the word my servo mounts are done I cant wait to see them much less use them.I also gound my axle cases I was bored and cant sleep.
06-26-2007, 10:30 AM | #75 |
I ended up takeing 3rd at the last comp with is rig.Ill post a vid up soon.my truck likes big holes |
