09-19-2007, 08:20 AM | #1 |
| what 40 series wheels to clear knuckle packs?
ive got narrowed axial beadlocks, and they wont work :(
09-19-2007, 09:38 AM | #2 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
I know these will work . http://www2.towerhobbies.com/cgi-bin...&I=LXDCW3&P=ML http://www2.towerhobbies.com/cgi-bin...?&I=LXFSM6&P=7 these or the Velocity 6 chrome narrowed to 2" tucked in nice also the XTM Thorns will work
09-19-2007, 11:43 AM | #3 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
I use XTM Thorns. They are a tad larger in diameter than 40 series and clear knuckle packs with ease. They come in gunmetal or chrome. I bought mine from hobby people. Here are the links: gunmetal is currently sold out http://www.hobbypeople.net/gallery/145521.asp chrome http://www.hobbypeople.net/gallery/145520.asp |
09-19-2007, 11:50 AM | #4 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
I'm running RC4WD narrow 40 series beadlocks with RUN2's knuckles and RCGUY 12-14mm adapters.
09-19-2007, 12:14 PM | #5 |
DOOH!!! Join Date: Feb 2007 Location: AZ
| Are you running out of ID or Depth? I had no issues with the ID using RC4WD knuckles and some delrin holders but i did have to fabricate some .312 extenders for a bit of added depth because i narrowed the Axials on the inside.... |
09-19-2007, 07:44 PM | #6 |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
i also was able to get the axials to work with aluminum knuckles. you just need to mount the batts to the knuckles with something like velcro or double sided tape so that they dont slide around and then crank down on them with a zip tie. it was a close fit but it worked.
09-19-2007, 07:59 PM | #7 |
| depth, mine are narrowed all stock axles. and my home made wideners add NO width
09-20-2007, 09:23 AM | #8 |
I like the velcro idea, mine slide a bit from side to side on the delrin with just a zip tie holding them.. Stang, I also had to remove the inner stiffeners from the rims for some added clearance, milled them down just passed the hex. Would be nice not to run the wideners though, 15.5" it tight on a 20" gate, but i don't see that happening since i'm already rubbing links as it is now.. |
