09-19-2007, 08:17 PM | #1 |
RCC Addict Join Date: Mar 2007 Location: des moines
| no more hustling for me
I gave up on the hustler..today my 18"wb black tcs stick showed up so I started to work on rebuilding my super rig..I got everything to gather easy and it turned out very nice..I got sick of the body I have painted so i wanted to try something new so I went with a little diff paint job lmk what youll think.. spec ds 8711 servo dx7 " thanks alot freetime" 3013's max's 3c lipo xtm wheels jp knuckles cvd's alum axle tubes alum axle cases the best 14mm hex's for the cvd's money can buy "thanks again" cut moabs in front 1100 mah traxxas rx pack 1/8 scale body homles hobby wiring for dual esc's pmipin front servo mount " thanks M.N RC " IM in no way trying to put down the hustlers..droop is just not for me Last edited by brushlessnut; 09-19-2007 at 08:55 PM. |
09-19-2007, 08:26 PM | #2 |
When can I expect the Hustler to arrive on my doorstep? You should look at a regulator for those servos, I have seen the light on this subject and my servos work alot better now, less heat too. Crazy paint where did the mask come from? |
09-19-2007, 08:32 PM | #3 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Very nice, I'm sure you'll like this over your old stuff. Tcs style sticks are just so predictable in handling.
09-19-2007, 08:38 PM | #4 |
when will I have the money I have been thinking abouting getting two cool bec's and I will when I get up on money again..Im very happy with it so far I hope it does well Im not sure how to set up a stick so Im sure I'll have to do alot of turning to get it right
09-21-2007, 09:13 AM | #5 |
well last night I got bored so I changed my xtm/moab xl's out for some axial beadlocks and moab xl's..I'll post some pic up soon..Im also trying diff foams IM still trying to fine the right weight for a super..I also put some fule tubing on my shocks to help limit them some
09-23-2007, 07:48 PM | #6 |
Well i had my first comp with the new super today. There was not a big turn out for supers, only 2, but i am very please with the way that it preformed. Now i am changing out the motors i decided to go with the new crawlmasters.
09-23-2007, 10:19 PM | #7 |
Trying to have Fun Again Join Date: Apr 2006 Location: In your fridge stealing a beer
Nice stick chassis. I'm planning the same motor choice but the older crawlmasters. Also Pm me if you still have that hustler chassis you know I like buying your tuber chassis and making you want them back.
09-27-2007, 05:27 AM | #8 |
Newbie Join Date: Aug 2007 Location: Long Grove, IA
brushlessnut, just wondering if you did any crawling anywhere over towards davenport? looking for someone to crawl with.
09-27-2007, 10:04 AM | #9 |
I wanna be Dave Join Date: Feb 2004 Location: on a Big Rock
| Good Choice for the new set-up |
09-27-2007, 02:29 PM | #10 |
Im very happy with it..I feel its alot better for my driving habbits..Im starting to get the truck dialed in..its turning out to be alot better then what I would have ever though..Ill post some pics up of the new tires and wheels...naw i only crawl on my rockpile or at the mn comps i just started going to the cmrcrc comps and Ill be making alot of them..Im not much of a crawler out side the comps I test my rigs thats about it..send me a pm and maybe I could crawl with you sometime |
09-28-2007, 07:32 PM | #11 |
I took the super out for a test run today..I still need to find the right spring setup |
09-28-2007, 08:17 PM | #12 |
09-28-2007, 08:30 PM | #13 |
I'll give you a dollar if you buy a different body for it! Can't wait to see it at the next event, it did extremly well for it's first time out! |
09-28-2007, 08:34 PM | #14 |
:-( I like my body |
09-29-2007, 01:48 PM | #15 |
Quarry Creeper Join Date: May 2007 Location: NCVRCC
Good lookin build. Do you comp that rig?
09-29-2007, 05:44 PM | #16 |
huh yes its one of my comp rigs
09-30-2007, 07:46 PM | #17 |
| truck worked great i ended up winning..Ill get a vid up soon
09-30-2007, 07:50 PM | #18 |
Yeah your run looked a lot cleaner this time around then with the hustler. |
09-30-2007, 08:02 PM | #19 |
| thanks droop just was not for me
10-05-2007, 08:13 AM | #20 |
well after I massed up and lost all my seting on my dx7..I went to work reseting everything and redoing my mixs..after play with the radio for about an hour I now have my throttles mixed and my steerings mixed.it was alittle hard to get use to but so far I really like it..i still need to edit the vid and get it up O and I lied Ill never go back to a brushed motor in my comp rigs aslong as jrh keeps the alwsome power coming
