Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: narrowed
Old 02-22-2004, 07:50 PM   #1
Default narrowed
should i narow the inside of the rim like you do the outside i did the outer rim now should i do the innner portion as well??
firstumustcrawl is offline   Reply With Quote
Old 02-22-2004, 08:26 PM   #2
bendforthebone
Default Re: narrowed
yes it will push more tread out out on the sidewall
badtodabone is offline   Reply With Quote
Old 02-23-2004, 06:44 AM   #3
yes you should do it, it helps with sde bite making you clod a beter crawler and improving on handeling
jmirsberger is offline   Reply With Quote
Old 02-23-2004, 08:51 PM   #4
everythings lookin good now im almost there all in need is your opinion on this one im gunna run the super torque jr servo in it is that what most are running?????
Old 02-27-2004, 08:30 PM   #5
RSI
is that the only up side to narrowing rims is having a side wall???? and flexxing???
RSI is offline   Reply With Quote
Old 03-02-2004, 10:12 AM   #6
Hope these tips help:
1 Narrowing the inner rim pushes the tires slightly outward making track width wider for more stability
2 Narrowing the outer rim pushes the tires slightly inward making track width narrower to help get in tight places
3 Narrowing both sucks the sidewalls in to put more tread on the edge of the tires for more sidebite. it also helps to give more sidewall support to tires with very soft sidewalls when you remove the foams.
rockdawg is offline   Reply With Quote
Old 03-02-2004, 07:10 PM   #7
i also nticed after doing this that my truck has about 1/4 inch more clearence under the diff
Old 03-03-2004, 10:53 AM   #8
How did you cut your wheels?
shadow is offline   Reply With Quote
Old 03-03-2004, 12:35 PM   #9
Moderator Rule Breaker
eric113's Avatar
hacksaw or bandsaw
eric113 is offline   Reply With Quote
Old 03-03-2004, 06:48 PM   #10
i used a hack saw but you cut use a dremel
Old 03-03-2004, 07:24 PM   #11
of course i messed up and cut the lip of the rim so now i gotta like rig something up lol i think it should be cool but yeh definetly becareful with a bandsaw it cuts fast lol
Old 03-29-2004, 09:44 AM   #12
Hacksaw works the best, nice and slow so you wont screw up your rims!
Take a file to it afterwards to clean em up, turns out great! (Just lay the rim down on its side and take a big file to it and make it flat)
SR5Dave is offline   Reply With Quote
Old 03-30-2004, 01:23 PM   #13
k cool thanx for all the tips
