10-27-2007, 09:48 PM | #1 |
| ClodBuster Tire
wondering if someone could tell me the overall diameter of the Stock tires on the Clodbuster. Im also wondering the mm size of the hex on the wheel hub. ( the brass hex on the spindle) Thank you. |
10-28-2007, 12:55 AM | #2 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
The hex is 12mm You know the tires are worthless for crawling right? Straight from the Tower hobbies website. Inside Diameter: 2.6" Outside Diameter: 6.25" Width: 4-1/4" |
10-28-2007, 05:11 AM | #3 |
Quarry Creeper Join Date: May 2007 Location: melbourne, australia
i use narrowed and cut clod tires with foams and they work fine, i got 3rd at a comp a couple of weeks and that was my first comp. next weekend i'm competing in australias national comp with them, and several people have used them before me with great success depends what type of rock your crawling on mnster, large smooth boulders there hopeless but small jagged rocks there almost as good as moabs |
10-28-2007, 09:41 AM | #4 |
thanks for the info. im not using them for crawling ..... wanted size info for possible use on a project but needed the hex size for sure. Thanks again. |
