Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: *** MSD BTA Steering Kit's 4 Clod's ***
Old 11-28-2007, 11:34 AM   #1
Arrow *** MSD BTA Steering Kit's 4 Clod's ***
I bet you guys never thought we would have clod parts Well we are the exclusive distributor for the Hand Bros Off Road products and we have 2 new things that will be on our website shortly. First is the Clod BTA steering kit. 2nd is a Nomadio aluminum steering king pin for the radio.
- Aluminum servo mount locates steering servo low for better CG.
- Allows full steering travel with CVD's
- No more servo wiggle
- All stainless steel hardware
- Beefy stainless steel steering link slides over rocks
- Self lubricating MCM plastic bushings eliminate slop at the knuckles
- Illustrated instructions for the DIY'er
- Fits front and rear on all linked chassis & torsion style chassis
- Fits front of TCS stick(will fit rear with minor mods)
They will be on our website shortly. PM me with any questions.
Pics:
installed on axle.
installed in the reverse position on axle.
Unimoger is offline   Reply With Quote
Old 11-28-2007, 11:45 AM   #2
pm sent....looks sick!
clarkrw3 is offline   Reply With Quote
Old 11-28-2007, 12:12 PM   #3
Location: Driving the Troysion Stick up the BIG BOY line!
Looks nice Ben. Like that kit the best so far!
cheapjeep2 is offline   Reply With Quote
Old 11-28-2007, 12:33 PM   #4
That looks awesome
What are you supposed to do about the axle tube brace? Looks like the whole is blocked.
Highmark is offline   Reply With Quote
Old 11-28-2007, 12:46 PM   #5
miniwheeler's Avatar
The upper brace is to support the axle tube where it bolts on to the gear case, not so much to make the axle c stronger.
The servo plate ties back into the gear case at the upper hole to give back that support. Yes the servo side plastic axle tube has some flex but it has not been a problem as of yet.
I have broken a handfull of plastic axle tubes but none have been the upper C on the servo side
miniwheeler is offline   Reply With Quote
Old 11-28-2007, 01:00 PM   #6
Originally Posted by Highmark View Post
That looks awesome
Will work perfect for the Integy cases!
Old 11-28-2007, 01:38 PM   #7
Looks like a pretty secure set-up.
For those of you not running aluminum tubes, our outer axle stiffeners will take care of breakage around the upper axle C. In this case, these would be direct bolt-ons with no modification required to the case.
Without the gearbox brace installed, you will greatly increase your chances of breaking the top ear off the axle tube with a hard fall/landing.
Last edited by Grizzly4x4; 11-28-2007 at 01:56 PM. Reason: Link to CPE vendor thread removed as per request.
CPE MT is offline   Reply With Quote
Old 11-29-2007, 05:41 PM   #8
thanks for the good words guys.
Old 11-29-2007, 09:01 PM   #9
Looks great! Will it fit when using adjustable motor mounts?
J Rock is offline   Reply With Quote
Old 11-29-2007, 09:22 PM   #10
you bet.
Old 11-30-2007, 08:14 PM   #11
i don't like the way you lose the axle brace on the servo side, otherwise looks good
if you had it so you could use a brace then it would be better imo
some_guy is offline   Reply With Quote
Old 12-01-2007, 12:58 AM   #12
I have been running this set up since 1 week after nationals and have not broken any axle tubes, cases or C's. I dont drive my super with a lite finger either.
hotwheels000 is offline   Reply With Quote
Old 12-03-2007, 11:31 AM   #13
Nice design, props to Hand Bros!
The lack of an axle brace shouldn't bother you. My 805 mounts don't use a brace, I haven't broken a C as of yet.
I ain't babying it neither.
4link4eva is offline   Reply With Quote
Old 12-11-2007, 06:30 PM   #14
I have run mine pretty hard and had zero issues.
Old 12-11-2007, 07:43 PM   #15
This is probably the nicest steering kit your going to find for your clod setup....I would highly highly recommend it!!
Martee is offline   Reply With Quote
Old 12-14-2007, 10:18 PM   #16
Thats pretty trick
Rok_Dok is offline   Reply With Quote
Old 12-30-2008, 12:37 PM   #17
I like the reverse position so it can be mounted on the front. Due to my axle brace mounts I don't think I would be able to do the BTA steering.
hemi528cuda is offline   Reply With Quote
Old 12-30-2008, 09:41 PM   #18
will it be able to use 1/4 servos?
bullet1231 is offline   Reply With Quote
Old 12-31-2008, 02:11 PM   #19
it has more to do w/ the rig falling or being dropped on end... i have hand bros on my rigs, and will upgrade to aluminum once my plastic axle housings break.
jedsled is offline   Reply With Quote
Old 12-31-2008, 09:42 PM   #20
Just purchased mine!
