12-02-2007, 10:52 AM | #1 |
Newbie Join Date: Aug 2007 Location: quebec,canada
| Rockbull III Versus TCS Stick
i just got me a set of clod axle and 2 55 turn lathe motor ,. now i need a chassis i looked all over and norrowed down my choice to 2 chassis ,. Rockbull 3 pro & the Stick , wich one to chose ? i would take the rockbull one because it look to me like i would get more setup options out of a rockbull type of frame but i see that the stick is very good performing chassis. i would like to be able to chose wich way i want to setup the rear axle (motor in the back) Is the Stick kind chassis limited when seting up the body ? look like the bodys are only hold by 2 body mount , 1 on each end , does it really hold it in place could i still use a rigid body like the bullhead original body ? wich one and why thanx in advance btw i already have a little experience with crawler , already have built 18 inch WB TXT wich easely climb stairs , |
12-02-2007, 10:57 AM | #2 |
Stick.
12-02-2007, 10:58 AM | #3 |
ok but why ?
12-02-2007, 11:25 AM | #4 |
Quarry Creeper Join Date: Jan 2007 Location: Alberta, Canada
Better performing and cheaper (at least for the Pimp Cane anyways, I'm not sure if the stick is cheaper than the RBIII).
12-02-2007, 11:28 AM | #5 |
the stick and rockbull 3 are about the same price
12-02-2007, 11:35 AM | #6 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
For performance the stick will be much better. There's realy no need for adjustability as it is already set up right to start with.
12-02-2007, 11:39 AM | #7 |
12-02-2007, 11:42 AM | #8 |
RCC Addict Join Date: Mar 2007 Location: des moines
x2 I will not likely go back to a 4link rig anytime soon.the tcs has a super light back bone and great brake over.the tcs stick have won time and time again and will keep on winning |
12-02-2007, 06:59 PM | #9 |
think i will go stick !! what about wb? look like they are out of stock can i get the longest one and easily cut it to have shorter wb anyone else ? anybody have tried or saw the rockbull in action ? can i use rigid body (bullhead or clod buster body)on stick chassis ? i don`t do comps i only want a very good performing chassis |
12-02-2007, 07:07 PM | #10 | |
12-02-2007, 09:42 PM | #11 | |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
If you are not comping and want to put a hardbody on a chassis, save some money and look at other chassis out there like the NN from TCS or many others available. No sence in spending the coin on a stick chassis that you will put a body on that negats all the ground clearance you gain with that chassis not to mention the CG you will loose with that body. I have used a rock bull chassis, it works as well as any 4 linker if you set it up properly,but there are cheaper options out there. More expensive isnt allways better. I am not knocking either chassis just trying to save you some coin if all you are going to do is bash Quote:
12-03-2007, 09:35 AM | #12 |
RCC Addict Join Date: May 2006 Location: USA
the rock bull chassis is ok for a 4 link design, but the stick is far better for competition rock crawling. if your looking for a good 4 link setup, and you don't want to go the stick route, RCguy.com has the Gecko 2 and Gecko 2 Pro which are really good and tcscrawlers.com has the NN which is really good.
12-03-2007, 10:54 AM | #13 |
Newbie Join Date: Nov 2007 Location: Nipawin
Well Flame me away but I personally like Tvp 4 link setups but they tend not to be the best at comps,which leads me to believe that there should be a separate class for torsion style chassis.The 4 link setup still looks like a crawler where as the Torsion chassis well just doesn't. just my 2 cents.
12-03-2007, 11:46 AM | #14 |
i dunno about the integy tvp performance , but i sure have a problem with Graphite chassis for a crawler, i`m kind of hard on my rigs. i don`t mind getting a torsion style chassis even tho i also thinks it does not look like a "real" chassis but is the TCS Stick really worth 220$ ,it does not look hard to fab. and all the aluminum parts look "home made" i only have the stock clod axle no servo mount, steering links etc. does anybody else makes torsion like chassis with shock setup ? Last edited by daver; 12-03-2007 at 11:50 AM. |
12-03-2007, 11:53 AM | #15 |
12-03-2007, 12:40 PM | #16 | |
12-04-2007, 09:58 AM | #17 |
Quarry Creeper Join Date: May 2007 Location: Grass Valley California
Check into the cane $ 45.00 if you buy it $10.00 if you build it either way it works great , no shocks needed but you do loose alot of ground clearance if you do not cut the body, and the hard shell body make it VERY TOP HEAVY they weigh almost 3/4 of a pound more. That will make a big difference when crawling. Depends if you want to look scale or climb VERY well. have fun either way its all up to you. |
12-06-2007, 05:52 PM | #18 |
Rock Stacker Join Date: Aug 2006 Location: Albertastan
This is a great thread. I am thinking of getting a Clod based crawler going and the stick looks like it may be the one I pick. Checked out some vids and the website they are sold on. ALL GOOD to me. By the way, what chassis came first at the Nats in Super?? Cheers Guys. |
12-06-2007, 06:03 PM | #19 |
| The "Stick" chassis only comes in certain predetermined lengths(12.5", 16", 17" and 18"), you must be talking about the Pimpcane chassis, which is NOT the "Stick" chassis.
12-06-2007, 06:05 PM | #20 | |
